removal of stickers
Old Dec 19, 2002 | 05:49 PM
doink's Avatar
removal of stickers
what is the best way to remove stickers? i want to take off my 4wheel parts sticker that goes across the top of my window. ia m thinking a blow dryer and a razor bladE?
Old Dec 19, 2002 | 06:06 PM
orangeman_85's Avatar
Yes, that is the best way. What I have found that works well and what I would recommend is to first use the razor blade to peel up a corner. Once you have enough of it up that you can grab hold of between two fingers, break out the blowdryer and just heat it up. Just work slow and carefull, and you should be fine. If residue is left after the sticker has been removed, you can try using one of those goop-be-gone products that get the sticker crud off. Hope this helps. Good Luck. Peace.
--Mike
:bounce2:
1uzRunner
63
Nov 10, 2018 03:58 PM
LotOMiles
Sep 14, 2015 11:45 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
FJtoyman
Sep 8, 2015 04:47 AM
gp66
Sep 7, 2015 08:29 AM
