removal of factory flares
Old Aug 6, 2003 | 05:56 PM
spoogy's Avatar
learned expensive lesson today - front mudflaps arrived (mailorder), and eyeballing them didn't seem to fit easily
came here and found wealth of info on flaps (or lack thereof) for 3G with factory flares
but the flaps do look like they may fit under the flare, except I can't figure out how to get the flare off to try it
there seems to be a plastic rivet-like thing on the bottom that's holding on to something, but afraid to just pry it out
any advice on how to get the flares off? or is that a waste of time and I should return them for Tacoma flaps per other threads?
thanks!
2000 4Runner SR5, factory flares
Old Aug 6, 2003 | 10:23 PM
PhxTRDRunner's Avatar
they need drilled out....and replaced afterwards, been there done that.
Old Aug 7, 2003 | 06:31 AM
rimpainter.com's Avatar
You can also get on the back side of each rivet and press the outer shell in with a small flathead. Once both sides have been pressed, the rivet will pull out, rendering them reusable.
The problems begin when you cant reach the backside of the rivet or they are destroyed from the above method.
Jun 1, 2021 01:51 PM
4x4-runner
Apr 18, 2017 09:08 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Sep 4, 2015 09:27 AM
skebe22RTE
Jul 31, 2015 02:03 PM
