Removal of '03 Stereo Bezel Housing
Old May 17, 2003 | 10:55 PM
GolfNut's Avatar
Question Removal of '03 Stereo Bezel Housing
How do you remove the bezel housing
around the 2003 4Runner stereo?
I've removed the clock, removed the
two bolts back of it, and the bolt behind
the drop down storage in front of the console. Tried yanking it off, but don't want to break the bezel housing. Does
anyone know if there are more fasteners to remove? Is there a secret to removing the bezel housing?
Secondly, would swapping a single CD
JBL stereo sound better than my non-
JBL single CD stereo?
Appreciate any suggestions.
Old May 17, 2003 | 11:06 PM
Rymin929's Avatar
The fancy little heater controls pop off (there clips and yes there tight) then there is I'f I remember correctly 2 phillips screws to remove. You must also take the center console trims off also to get the main bezal off...
Professional opinion, you don't want the JBL setup if you plan on changing it out and or adding to it in the end.
Old May 25, 2003 | 09:43 PM
GolfNut's Avatar
'03 Stereo Bezel Removal
I case anyone is trying to do this, removal of the
console is required first. Remove the shifter knob, and pop the top of the console out (no bolts). Remove the two bolts, one on the left and one on the right and tilt the bottom of the console out. Loosen the bottom panel of the driver's side dashboard, and remove the bolt on the left side of the stereo bezel. There is a bolt right above the drop down panel below the AC control panel that must be removed. Pull the clock, temp, MPG meter panel off (no bolts or screws) and unplug the panel and remove. Then
remove the two bolts under the front center of the stereo. The bezel will now pull off, and all that is required is to remove the two electrical connectors, one for the rear window switch on the right and the emergency flasher on the right. To remove the stereo, remove the bolt on the right and the left.
Was trying to install a Kenwood CD changer via a SoundGate interface "KenToy1", but alas, none of the electrical plugs fit. :=( Any suggestions?
I did notice two unattached electrical plugs in the console. Does anyone know what they are for?
A cellphone connection? Or Toyota CD changer output/power connection? Preamp out?
What to hookup my Kenwood changer. Guess
I could spring for the clone of the Toyota changer or the real thing.
Old May 26, 2003 | 07:52 AM
impulsebrklyn's Avatar
i have everything posted in my web page below sorry i hav been away for a week. should have done a search i posted everything a few months ago.
jasonty
41
Dec 23, 2018 01:00 PM
theking11863
Mar 19, 2016 09:36 PM
Flossy
Aug 5, 2015 05:14 PM
Esibnitsud
Jul 30, 2015 08:19 PM
