Recommendation - O2 Sensor 1999 4-Runner
Old Sep 16, 2007 | 07:12 AM
icerunner's Avatar
O2 sensors
Originally Posted by Potomacduck
Guys, these engines are extremely dependant on their sensors. If your Check Engine Light is on, don't drive too many miles before getting it checked out. A bad O2 sensor or bad MAF will throw off the fuel/air ratio and can easily destroy the catalytic converter.
Do not defer maintenance! It will cost you dearly in the long run.
Totally agree,
Geeez, you can get a pre cat o2 for 89.99 at ......what parts store does everyone recomendhere again?? TRD ....something something....
I just bought a "DENSO" "1st time fit" 02 sensor for my 99' and I did notice a difference as well in MPG. I just did the Pre cat O2 sensor to save some cash and i worked....I think the (after CATTY) o2 sensor is good for much longer...I hope so, because Idon't tink I'll be able to get the bolts off....
HERE IT IS :
and the store is..........
UNDERDOG RACING DEVELOPMENT (or URD)
(for a DENSO" "1st time fit" 02 sensor)
I paid 79.99 for a PRE CAT O2 sensor....an a little word to the wise, Also replace the o2 bolts...as I had a real Bi 'ach of a time trying to remove the bolts from my o2 sensor....
a 2 hour job!!!! Midwest road salt...hope that helps out a "brother in need"
FYI some say these o2 sensors are 75,000 Max sensors....AND with outr engines THe sensors can go out and your fuel economy can suffer a long time even without a Check Engine Light (cel) Also check withyour V.I.N as I think some "California versions" of the 3.4 call it a AIR /Fuel sensor/A/F Sensor....?
Good luck
Old Sep 16, 2007 | 04:48 PM
Ironmike4x4's Avatar
Originally Posted by kenwoodrunner
you need to read the data from each sensor to see how lazy it is, and then make ur decision. so you are going to need a DATA reader (not a code reader) to read the data and then you will need someone to tell you what the data means. just replacing sensors because it is time could be a waste of money if they are operating correctly! mike
I agree. When a customer asks me about replacing an O2 sensor I just tell them up front; Yes you can replace them at certain mileage intervals, but personally I'd just use a scan tool and check the pre cat and post cat readings to see if they are both working properly instead of shelling out $80+ for a brand new one. Should you decide to replace them PLEASE do not go out and buy the universal O2 sensors. If wired properly then it's fine, but if not you go through the headache of taking the sensor off and trying to reconnect the wires and etc. when you would've been better off doing the same job once with a brand new sensor with a connector.
Old Sep 17, 2007 | 10:00 AM
Tark's Avatar
I have a rear OEM o2 sensor for sale if interested
$50 shipped.
Longbed 90
Mar 11, 2019 12:38 PM
crammit442
7
Nov 29, 2017 12:30 PM
Dobich
Sep 14, 2015 11:15 PM
markf1
Sep 3, 2015 01:23 AM
izzmee
Aug 17, 2015 10:20 AM
