Old Apr 5, 2016, 08:44 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Exterior Guides
Print Wikipost
Rear Wing Install
Old May 31, 2006 | 06:00 PM
Los's Avatar
Los
Ok folks, I just measured the spoiler... and then used the brake light to as the centering device since its centered on the truck. After I made sure that was lined up I measured how far in on the tailgate the spoiler sat. Once I made sure those were even, I drilled. Turns out its straight and centered. Parked next to another runner the other day and looks the same. So i guess Im good
Old Jun 1, 2006 | 08:43 AM
DoubleZero4x4's Avatar
Sweet...how much did the parts cost you?
Old Jun 1, 2006 | 06:03 PM
Los's Avatar
Los
The parts didn't cost much, I didn't end up using those screw taps I was talking about previously as lowes had self tapping metal screws. And after i drilled the screw in i saw that the screw was tight on the hole and was strong enough to hold itself in.
The thing that helped line up the spoiler was I put a piece of painters tape over the brake like and measured center on it. once i put the marker lines on the tape it was easy to line up the hole for the brake light.
I did take the screws out and paint the stripped hole so it couldn't rust.
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
deepmarsh
Aug 6, 2015 03:44 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
