Rear Window Washer Resevior?
Old Feb 7, 2003 | 07:05 AM
JohnM's Avatar
Since I didn't get an owners manual with my used 2000, could someone tell me where the resevior is for the rear window wiper?
Sorry for the total noob question.
Old Feb 7, 2003 | 07:13 AM
Cebby's Avatar
Huh?
Mine draws from the front, although I have a '93. I would suspect yours does the same, but I'm not sure. In the past, I have experienced some freezing of the washfluid tube. Only a couple times when it was REALLY cold.
Welcome to the forum!
Old Feb 7, 2003 | 07:23 AM
JohnM's Avatar
I thought about that possibility but then dismissed it...Once again, I'm wrong. Happens every day.
Old Feb 7, 2003 | 07:25 AM
jacksonpt's Avatar
Senior Member
My 96 draws from the front as well... there is a separate pump, but a single resevoir.
Old Feb 7, 2003 | 07:26 AM
CTB's Avatar
CTB
Same thing for mine....just wanted you to think about being wrong twice!!
Old Feb 7, 2003 | 02:18 PM
HaveBlue's Avatar
Me three, or four!
Side note:
I switched from blue washer fluid to the more premier Rain-X and haven't suffered a line freeze yet. Plus, it get's rid of the pesky magnesium chloride build up from tire spray.
Old Feb 8, 2003 | 09:37 AM
kerrs's Avatar
If you look closely at the resevoir you'll see the pump for the rear washer is higher than the front one, so if the rear stops working it means your getting low on fluid.
Clever Eh!!
Kerr
Jun 1, 2021 01:51 PM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
coryc85
Jul 6, 2015 04:07 AM
