rear sun deflector?
Old Jan 8, 2008 | 12:28 PM
pkt1213's Avatar
A 3rd gen. I think it came off an 01 limited.
I've got everything except the threaded sleaves.
Old Sep 17, 2008 | 01:52 PM
Jason B's Avatar
Originally Posted by Ron Helmuth
Sloan that is a good price for a new one from TRD of Dallas-however the wind deflector does not include the mounting hardware and stanchions-the black plastic pieces that lift it away from the liftgate
I have a template from Jacques-the superb parts guy of TRD Dallas for the placement of the threaded inserts into the rear liftgate. That is a separate Toyota part number-sorry no I do not know what it is.
I am hesitant myself to drill holes in my liftgate-so I have a shop lined up to do the work. If you need the template just send me a private message. It has been on my "to get done list" for almost a year now....
Yes it does help the wind to draft down the back window so that loose dirt is blown away and moisture will tend to dry itself out.
Wait, so you are saying if you buy the rear wind deflector from Toyota, it doesn't have the brackets that mount it to the truck???
Old Sep 17, 2008 | 02:38 PM
Team420's Avatar
I got 1 at a pick n pull, think i paid $10, just took the hardware, then measured, drilled, and used rtv to seal it... mine is a 94 tho, and it does help with dirt, rain etc...
Old Sep 19, 2008 | 12:47 PM
Ron Helmuth's Avatar
no longer sold at the dealership
Correct Jason B. -you would have to buy the entire "kit"-and 3rd gen deflector kits are no longer available at my local dealerships.
Best to just buy one complete at a junkyard. Irbis Off Road has a number of these also stockpiled.
Old Sep 19, 2008 | 01:41 PM
  #25
bobs01sr5's Avatar
Or you could opt to put a jaos spoiler on their instead looks sweet that black aluminum thingie does nothing...well it makes it looked "finished"
Old Sep 20, 2008 | 02:56 PM
  #26
waskillywabbit's Avatar
I've got a rear spoiler from a 97 4Runner sitting around my shop on a busted rear hatch.
Old Sep 20, 2008 | 05:45 PM
  #27
Jordan Petry's Avatar
I disagree, the spoiler actually does a decent job of forcing the exhaust fumes away from the vehicle when the rear window is open. When I'm driving 0-20 MPH it doesn't do anything but anything above 25-30 ish MPH it works excellent at keeping the fumes from entering the window.
Old Sep 21, 2008 | 08:38 PM
  #28
riverrat's Avatar
...that black aluminum thingie does nothing...
BS.
As a former owner of a 1st gen (1988) that did not have this feature, I can assure you that the spoiler or whatever you want to call it is quite effective at reducing dust buildup on the back window. There is a huge difference with my new runner that has it. I haven't been through a winter with it yet, but I bet the spoiler will also help keep snow from packing on there as well. And then there is the aforementioned exhaust fume issue.
Old Sep 23, 2008 | 09:12 AM
  #29
Jason B's Avatar
How is the condition?
Old Sep 23, 2008 | 09:17 AM
  #30
Not dented or gashed. It probably needs a coat of fresh paint as it looks faded from the sun. Other than that it looks pretty normal to me.
Old Sep 23, 2008 | 02:53 PM
  #31
Sloan's Avatar
where do you have to drill on a 4runner to install one?
Old Sep 23, 2008 | 03:14 PM
  #32
Fink's Avatar
There are a total of 4 holes I believe.
I'm not exactly sure how the brackets mount but if you look at the pic that Wabbit posted you can see the 4 screws in the wing itself.
I would imagine there are two per bracket also.
Shouldn't be all that hard.
Go to your local Toyota dealership and get a print out of the exploded view they have.
Or, if you PM me your VIN number I can get one from my dealership and fax it to you or .pdf it and email it.
Fink
Old Sep 23, 2008 | 03:25 PM
  #33
DeathCougar's Avatar
Each bracket actually has 3 holes, so 6 total. Two exposed, and one more hidden in the center of the bracket, under the actual wind deflector.
terminator
Jul 27, 2015 07:13 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
