Rear spring help !!
Old Oct 20, 2013 | 08:44 AM
smitty52's Avatar
Rear spring help !!
Alright, i have posted a question about leveling my '96 standard cab, but no replies, and I have searched before I posted and could not find any answers. I have replaced both sides upper/lower ball joints and new billy 5100's, set on the 2.5 lift. My original leafs are flat at best, actually the arch is a bit inverted, so i am wanting to replace them ASAP, my question is, do I replace with stock, as I understand the stock leafs caused the rear to be about 2" higher than the stock front and now with the new frt. shocks would the truck sit "level" with oem leafs, or do I purchase a lifted spring to get it back level? presently the frt. is about 3.25 inches higher. Where is a good place to get oem style springs if, that is what y'all suggest? And if lifted springs are in order, how much lift and what's the best brand? Thanks in advance-Mark
Old Oct 20, 2013 | 09:46 AM
Redeth005's Avatar
I cant answer this question for you because i never had an IFS lift before i SAS'd, but i would most definitely recommend old man emu springs if you're going with stock style. You should PM your question to Chefyota4x4. I know he had a small 2.5 or 3" lift on his truck before he SAS'd. He'd probably be able to answer better then I.
Old Oct 20, 2013 | 11:03 AM
smitty52's Avatar
Thanks Red, btw who would have "stock" style emu springs, the few vendors I have called only have lifted leafs. I will PM Chefyota Asap
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
terminator
Jul 27, 2015 07:13 PM
yourrealdad
Jul 21, 2015 11:13 AM
Nickdigg
Jul 7, 2015 06:04 AM
