Rear End noise
Old Jan 21, 2004 | 10:34 AM
tpg013's Avatar
Junior Member
Rear End noise
I sold my '94 4Runner to my sister and every time I see them i also take a good look at the ole girl. I took her out for a drive because my sister told me it was making a funny noise and it sure was. Sounds like it's comming from the right rear tire. It's almost a humming type noise and sounds something like "waa-waa" depending on how fast you are going. I thought there might be some ice or something rubbing , but a visual inspection was clean. My theory about there being a little ice caught in the drum was squashed when my brother in law told me he took it on a good 1 hour trip. The tires have a few miles on them so I'm hoping it's just that. Anyone have any ideas what else it might be?
Old Jan 21, 2004 | 11:01 AM
WT's Avatar
WT
Possible bearing going bad
Old Jan 21, 2004 | 11:06 AM
85runner's Avatar
Rotate you tires before you try to figure out what it is.
Old Jan 21, 2004 | 11:28 AM
86toyota's Avatar
Are you sure it's not the rear U-joint?
Old Jan 21, 2004 | 11:52 AM
4runner4ever's Avatar
Wheelbearing. Jack it up and feel if there is any play in the wheelbearing by trying to 'lift' the tyre. Only takes a minute and you know what the problem is.
Old Jan 21, 2004 | 12:18 PM
tpg013's Avatar
Junior Member
How mych of a PITA is replacing rear bearings? I have never done it and wonder what I'm in for should I decide to help them out.
Old Jan 21, 2004 | 12:30 PM
snorkleman's Avatar
Your rear bearings are on the axle shaft and they are pressed on. If you don't have a way of pulling them off (bearing puller) I would recommend taking them to someone with a puller. You also will need a press to get the new ones on. I don't think it costs that much and the hassle can outweigh the costs if you don't have the right tools.
I've seen homemade pullers and presses made to do this.
Old Jan 21, 2004 | 12:34 PM
85runner's Avatar
I really would suggest just rotating the tires before you do anything else.
Old Jan 21, 2004 | 12:41 PM
snorkleman's Avatar
Yeah I agree with that.
Also have you tried jacking the rear up and manually turning it and listening for anything. You can also check any play in the u-joints. Also check the play in the carrier bearing for the driveshaft. Sometimes they can make a low noise when worn.
But definately check all the easy stuff first before assuming the worst.
Old Jan 21, 2004 | 12:50 PM
tpg013's Avatar
Junior Member
keep in ind it's not ym truck anymore. I suggested to my brother in law to roate the tires and even put the spare on the right rear and see aht happens. I'm sure in the end I'll be the one to fix it. based on that you can bet I'll go the easy route first.
Daneums
Aug 20, 2015 05:36 AM
razorman8669
Jul 12, 2015 12:13 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
toyoda8488
Jul 5, 2015 10:18 PM
