Rear Differential or drifeshaft noise???
Old Oct 17, 2012 | 06:07 PM
Double Tap's Avatar
OK, two questions for you guys. Over the last month, there has been a noise coming from the drive shaft or the rear diff. I do not think it is the u-joints because from a stop, I get going and maybe 5 feet after starting there is a clunk, clunk, clunk noise that is hard to describe. I can barely feel it in the floor when it happens and everything is smooth driving from that.
Also, I changed the rear diff fluid a few months ago and noticed what is in the pic yesterday when taking a quick look underneath. I see many 4runners every day and never see this. I used a new crush washer and it is tight. Also, there is no dripping of any sort and it is just like oil and dirt. Is this normal, or should I pop it open?
Old Oct 17, 2012 | 07:17 PM
BigBallsMcFalls's Avatar
stethoscope
jack stands
assistant
listen to diff up close
Old Oct 18, 2012 | 03:57 AM
DRCOFFEE's Avatar
It's time to check your diff fluid level. I hope it's the u joint because if the diff is making that noise, it's too late to save it
Old Oct 18, 2012 | 03:10 PM
shelshelly90's Avatar
I have the same problem but mine is more of a click than a clunk, I determined mine to be the carrier bearing
Ladythump
22
Nov 9, 2015 08:53 AM
jerusry
Oct 19, 2015 05:28 PM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
AaronM
Jul 8, 2015 07:15 PM
