Rear diff seal replacement (I did search)
Old Apr 9, 2004 | 05:53 PM
okidoc's Avatar
The seal where the driveshaft yoke goes into the pumpkin is leaking. What are the tricks to replacing it? If I remove the yoke does it mean I have to relash the gears? Or can I just mark the nut and then retorque to specs?
Old Apr 9, 2004 | 06:22 PM
Designsbyme's Avatar
I need to know this too. Mine is leaking as well and as soon as I get my truck running again I need to fix it. Bump Bump....
Old Apr 9, 2004 | 07:05 PM
toy283's Avatar
To do it properly, you should really remove the third member so that you can reset the pinion bearing preload (7.8-11.3in-lbs). Barring that, I'd mark the nut and then tighten a little (maybe 1/8 turn) beyond where it was when you removed it.
Old Apr 9, 2004 | 07:22 PM
okidoc's Avatar
Code:
So in order to set the gears up properly you need to chalk the ring teeth in order to determine the best torque right? Sounds like a serious PIA.
If I'm going that far into the rear what else should I do? My axle seals look good but if I'm pulling the axles should they be replaced anyway?
Old Apr 9, 2004 | 08:06 PM
Blair's Avatar
Originally Posted by okidoc
Code:
Took me a couple times, but I got mine. Just match mark and make sure you don't crush the sleeve. Some say use RTV, some don't. I did the last time and it held great. I din't adjust preload at all.
Old Apr 9, 2004 | 09:30 PM
toy283's Avatar
Code:
Nah, you torque it until it takes that amount of force to turn the pinion. That is why you need to remove the diff from the housing to check. Having the dead weight of the axles, tires, etc. is gonna dramatically increase the amount of torque needed to rotate the pinion.
Team420
Jan 12, 2021 04:57 PM
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
merc1100sc
Jun 26, 2015 05:24 PM
