Rear anit-lock breaks???
Old Oct 1, 2003 | 02:15 AM
mattk's Avatar
Hey guys ive got a '95 Runner that just yesterday my rear anti lock brake light came on and wont go off! Has anyone lese here had this problem? I have about 150,000 miles on the truck and have had no brake problems what should i look for or where should i begin?
Old Oct 1, 2003 | 02:47 AM
keisur's Avatar
maybe a sensor wire got clipped or fried. I'd start there right at the wheel and work your way toward the front. Then I might pull the sensors and clean them and reinstall them in the axle tube. If they are like mine they are held in by one 10mm screw and the compression of an oring. just take out the screw and use a flat head screwdriver to pry it out. clean the grease off of it, clean the oring and regrease it and put it back in. If that doesn't work then I would say a sensor is bad.
Old Oct 1, 2003 | 05:00 AM
Victor's Avatar
The sensor in the 2nd gen is built into the rear axle. There is an extra harness that exits the top of the axle.
Old Oct 1, 2003 | 07:44 AM
Robinhood150's Avatar
To add to this, the FSM or chiltons explains how to do an electrical test to see if this sensor is bad.
Old Oct 2, 2003 | 02:28 AM
mattk's Avatar
Thanks for the replies guys. Im gonna check it out next week......im gonna be gone all weekend so it will have to wait. I have a Haynes manual but it says to take it to the dealer which im not gonna do........can any of you guys tell me how to test the sensor step by step or scan in the directions and post them here. If not i understand illl try and get another manual. Thanks in advance!
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
CanRunner
Jul 20, 2015 01:29 PM
kvanzandt1
Jul 18, 2015 10:15 AM
colasurdo
Jul 16, 2015 11:37 AM
