RB sell me a kit
Old Dec 9, 2004 | 02:30 AM
epic37311's Avatar
RB sell me a kit
I got a 83 2wd. Want 2 to 3 iches, where do i send the money?
Old Dec 9, 2004 | 03:10 AM
3car's Avatar
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Old Dec 9, 2004 | 08:16 AM
4Crawler's Avatar
Not sure if 3" will work on the early 2WD, if willing to try, see:
General body lift kit info:
Body Lift Kit Installation Instructions:
http://www.4crawler.com/4x4/ForSale/...ft_HowTo.shtml
Add $2.00 for a printed copy included with your kit, or print your own copy
Body Lift Kit Pricing Info:
http://www.4crawler.com/4x4/ForSale/BodyLiftPricing.txt
Code:
1979-1988 Pickup/Hilux Body Lift Kits:
  Kit:           Cost/1"   Cost/2"   Cost/3"
  B              $ 60.00   $ 76.00   $ 92.00  (Ult. blocks only)
  D              $ 85.00   $101.00   $117.00  (Kit B + h/w only)
  F              $ 95.00   $111.00   $127.00  (Kit D + front bumper or radiator)
  H              $105.00*  $121.00   $137.00  (Kit D + front bumper + radiator)
  BS             $  8.00   $ 10.00   $ 12.00  (Per pair of bed spacers, 1 or 2 pr.)
  AT                 n/a   $ 40.00   $ 50.00  (Extension for A/T shifter ****)
  SE                 n/a   $ 30.00   $ 30.00  (For 1-piece steering shafts)
  P              $ 55.00   $ 55.00   $ 55.00  (Poly body mount bushings)
  CLR            $ 14.00   $ 14.00   $ 14.00  (Custom color lift blocks)
  HD             $ 15.00   $ 15.00   $ 15.00  (Upgrade cab hardware to Grade8)
  SL                 n/a   $ 15.00   $ 20.00  (Shift Lever extension/per lever)
  DOC		 $  2.00   $  2.00   $  2.00  (Printed installation notes)
  Typical Kit    $ 95.00    $121.00   $137.00  + shipping**
                     (F)        (H)       (H)  (Typical kit contents)
Notes:
- If you have trouble with the columns not lining up, be sure to select a
"mono-spaced" font for your e-mail reader, such as "Courier"
- See above referenced file for description of the kit letters
- Kits B/D/F/H are mutually exclusive, that is kits F and H include kit D/B
- For ordering information, please provide a list of items desired and a shipping
destination (as noted below).
(*) Optional at that height
(**) Zip code/country needed for shipping and sales tax calculation
(***) Requires drilling, 2"+ flip stock bumper brackets & redrill holes
Front bumper bracket on 2000+ 4Runner/2001+ Tacoma, will need to remove
or raise the inner bumper for the outer bumper to clear when lifted
(***) For linkage style early Toyota transfer case shifters, if your t-case shifter
is direct, this is not needed nor will it even fit.
Likely you'll need the steering shaft extension along with the lift blocks and longer bolts. Let me know where you want me to ship the kit to and I'll send you a total and ordering instructions. E-mail or PM works best to contact me, I don't monitor all these web forums every day, so you are lucky I found this post.
jerusry
Oct 19, 2015 05:28 PM
shisha1999
Sep 21, 2015 08:22 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Sep 4, 2015 09:27 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
