Radiator Reservoir-near empty
Old Jan 11, 2003 | 06:02 PM
RgrChu's Avatar
Guys and Gals,
I was under the impression that the radiator reservoir should be between the full and low lines......Mine is always on the low side.....I was told at my 90,000mi service that the fluid level in the radiator level will vary while I drive and that I was probably only noticing it when it was on the low side......
My radiator seems full whenver I check.....and I have no overheating problems...also no leaks noticed....
Am I just worrying too much? TIA
Old Jan 11, 2003 | 06:10 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Add coolant to the reservoir to the "low" line while the engine is cold. It should return to that level each time the engine cools down after heat-up. Otherwise, a hard-to-find leak or headgasket problem may exist.
Old Jan 11, 2003 | 06:36 PM
Jay's Avatar
Jay
I agree w/ Rick F.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
mreagen
Oct 5, 2015 04:27 PM
scott90
Oct 4, 2015 09:21 AM
Matthew Perez
Sep 28, 2015 05:43 PM
