Is this radiator cap bad?
Old Jan 2, 2016 | 09:24 PM
Guzard's Avatar
Is this normal?<br/>98 4Runner. I got home and heard the coolant boiling and over flowing from the coolant reservoir. Lost about a gallon.
Old Jan 3, 2016 | 10:45 AM
wyoming9's Avatar
Red face
What is all that dirt from??
The only way to really test a cap is with a coolant pressure tester.
Ones that look perfect fail ones that look really bad are fine.
After market caps have been real junk lately.
I get mine at the dealer anymore.
Old Jan 3, 2016 | 11:36 AM
Y8rodo's Avatar
Doesn't look good, If in doubt replace it cheap compared to what could happen . ,, while the cap is off check for bubbles while the engine is running. If bubbles, investigate for POSSIBLE head gasket failure
Old Jan 3, 2016 | 12:48 PM
Guzard's Avatar
It's not dirt.
This is a new one from Napa. So now there's a piece of the cap in the coolant. Time for a flush right? This sucks! We're supposed to get a bunch of snow this week.
Old Jan 3, 2016 | 02:49 PM
habanero's Avatar
Ha, you figured it out. Mine did that but the pieces were still in the radiator neck so they was easy to get out. You've prolly already looked, though.
Hopefully that Napa cap works better than the Auto Zone one I was stuck with buying. It lasted a whole year, woo. hoo. Luckily the second time the Yota dealership in town was open that time. All good ever since.
Old Jan 4, 2016 | 12:55 PM
Marc's Avatar
I don't think the missing piece can go anywhere but the area at the top of the rad.
Old Jan 11, 2016 | 06:19 AM
Sdsupra760's Avatar
Ya its no big deal if a lil piece like that is in the upper tank. And a flsuh wont get it out anyways so just fill it back up with coolant and water mix and burp any air out of the system and run it. See if it doesnt over heat sn hope there i no damage to the motor. You said it sounded like it was boiling over? And yes aftermaket caps suck really bad so get one from the dealer. Bad caps and low coolant levels from failed caps have been known to overheat motors and warp heads and ruin head gaskets. Always keep an eye on your coolant level!
Old Jan 12, 2016 | 06:22 PM
Guzard's Avatar
So I'm flushing it right now and not finding that little piece. You think if I took off the radiator and flipped it upside down it'll come out?
Which way does the coolant flow? From the top hose to the bottom? Oh and I took out the thermostat so it immediately starts flowing.
Old Jan 12, 2016 | 06:44 PM
Sdsupra760's Avatar
Do not worry about it. Ur wasting your time. Not trying to be rude. Honestly
Old Jan 13, 2016 | 10:01 AM
Jomoka's Avatar
Yeah, it's not really going to cause any issues. Other than you worrying about it, I guess. But it's not worth the effort of taking the radiator out of the car to shake it out of there. Just put a good cap on it, fill it with good coolant, and call it a day.
beadsworth
Jan 6, 2016 12:18 PM
68jimmy
Dec 22, 2015 09:21 PM
SunnyCoastSteve
Dec 17, 2015 06:52 PM
87roctruk
Dec 5, 2015 06:21 PM
Amnesiac
Nov 18, 2015 04:11 AM
