Quick Injector question... I only have 2 hours.
Old Jun 20, 2003 | 06:52 AM
asudan96Runner's Avatar
Will these injectors work for my 4runner?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2419441230
Please don't poach these.
Dan
Old Jun 20, 2003 | 07:19 AM
TOR
Injectors
I would stay away personally. No idea how they've been maintained whats been run through them or if they still really work. They probably won't work due to the seals and orings on them. If they did you and that would be a big if you would more than likely either have to replace your ECU or map sensor.
Todd
Old Jun 20, 2003 | 07:23 AM
If they are flow tested and cleaned, which it says they are, then I am not worried so much about condition.
I know I need injectors from a 92-96 Non-Turbo Supra, so I think these will work. I'd prefer newer ones, but as long as they are cleaned and flow within 2% of each other, I'm happy.
I just need to make sure these fit.
Dan
Old Jun 20, 2003 | 07:56 AM
TOR
FUEL INJECTORS
Spoke to our heavyline tech he said that if they are Bosh style then they should work. His question was, what do you need them for. He suggested getting an after market fuel pump first to jack it up to 60 psi.
Todd
Old Jun 20, 2003 | 08:16 AM
Todd,
the fuel pump is also in the works, as is a fuel management computer. (S-AFC)
I run a supercharger, and as of now I am running lean because the stock injectors cannot handle the duty cycle.
larger injectors will give me the ability to stay in the right A/F mixture range (14.7:1) and also give me more horsepower while lowering EGT Temps.
Are the injectors in our trucks considered "high impedence"?
Dan
Old Jun 20, 2003 | 09:14 AM
ravencr's Avatar
yes, they are considered high impedance!
Chris
Old Jun 20, 2003 | 09:18 AM
ravencr's Avatar
Check www.gadgetonline.com, and it will tell you if they will fit or not.
Chris
moparbay
Oct 6, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
themightykhoner
Sep 18, 2015 02:28 AM
larrys93pickup
Sep 17, 2015 07:05 PM
Kytowboater
Sep 17, 2015 11:17 AM
