Questions on Husky's
Old Dec 17, 2004 | 05:41 AM
KING's Avatar
My truck is now carpeted with Husky's and they look great and so far love them.
I have one problem though. Since the liner is designed to fit on the entire surface, it is interfering with my gas pedal. The liner is seated under the pedal and in line with the "pedal rod" so it makes the gas pedal extra hard to accelerate.
The gas pedal was already a bit stiff before and this now makes it extra stiff.
The only way I've thought to resolve the problem is by cutting a small piece along the rod but I would hate to do so since the liners are new. Another thing was to heat the surface and mold it to be pushed down from the gas pedal.
In conclusion, any of you second genners had the same problem when putting your new liners in?
Old Dec 17, 2004 | 05:49 AM
kpooch75's Avatar
Mine were in when I bought my runner, let me go ahead and tell ya you are going to love em. As far as the pedal problem, mine look like they were cut because of what you are describing. Problem is, whoever did it cut it so that if the liners slide back towards the seat a little the gas pedal can get stuck under it when fully depressed. This has cause more than a little scare at times because I would think I was letting off of the gas, and I was accellerating full throttle ! Now I'm used to them though and every time I get in I make sure to kick the liners forward just a bit. Hasn't been a problem since. Good luck, let us know what you decide to do.
Old Dec 17, 2004 | 05:51 AM
KING's Avatar
Good point and thanks.
So it looks like a "V" cut would solved that problem.
Old Dec 17, 2004 | 03:02 PM
Corey's Avatar
Co-Founder/Administrator
Yes, cut a good size hole.
I posted here a long time ago I almost got into two wrecks from nailing the throttle, only to get it stuck in the small hole I cut.
((Hole is mucho bigger now))
Both times I had to shut the engine off, and almost had to steam clean my seats.
Old Dec 17, 2004 | 07:08 PM
UKMyers's Avatar
I cut a good chunk out of mine too. I was testing out my Airbox mod and nailed it in the driveway just to hear the intake noise and it stuck wide open. I got her shut down pronto but I saw around 7K on the tach I didn't care how purty they were after that I hacked a big chunk out!
Old Dec 17, 2004 | 08:14 PM
KING's Avatar
Well its final.
Looks like all second genners encounter the same problem.
Too bad for the new Huskys but oh well.
Thanks.
rocket
Jan 21, 2016 05:03 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
