Question about Detroit true-trac in ADD trucks
Thinking of installing a Detroit True trac LSD in the front diff but have a few concerns. Does anyone know for sure if the design of this LSD allows one side to turn independently of the other, without turning the whole ring gear along with the driveshaft? I really don't want that to be happening when im not in 4x4.. Thanks!
ADD disconnects the diff from doing anything, but your driveline will still spin. You need to switch to hub locks vice ADD. It is the preferred "soft" locker for the front axle. Soft because unlike a Detroit it doesn't smack your thumbs when it locks. Now please keep in mind if you put a locker in the front & have a locked t-case you must keep your thumbs out of the wheel, or you will lose them. A trip to the emergency room to reattach them is not a fun excursion. The big danger is a broken axle since all engine power goes into spinning the wheel, its freaky as it tries to take fingers and thumbs.
Personally, I've seen way too many non-functioning True-Tracs to recommend one. If you really need a locker, LSDs are no substitute.
There were several threads in here before about the front trutrac. there were a lot of discussions about the front based on their experiences
here's one:
https://www.yotatech.com/forums/f116...t-diff-264248/
here's one:
FS[PacSouthWest]: Front and rear 5:71s for 7.5" and 8"
Dezert_Yota86
May 17, 2017 04:49 AM
FS[NorAtl]: 4.10 IFS front diff out of turbo truck
MAINETOY
Mar 30, 2016 05:37 AM
