Proper TB adj. on the 3.0?
Old Sep 19, 2003 | 01:54 AM
Yoter's Avatar
Guest
Question Proper TB adj. on the 3.0?
What is the proper way to adjust the throttle body and how many RPM's should it idle at?
Old Sep 19, 2003 | 04:38 AM
Victor's Avatar
Idle is 800 RPMs which is the needle just above the 750 mark on the tach for me (confirmed by the emissions test computer). Adjust the idle with the screw that faces towards you - tightening it in will lower RPMs and loosening it will raise them.
Old Sep 19, 2003 | 06:18 AM
CTB's Avatar
CTB
Just for your info, I idle at 750 rpm when it is warm outside, and just slightly higher in the winter time (as if SC really has a winter!).
89fourrunner
Feb 17, 2016 06:52 AM
tobylab
Jan 18, 2016 07:06 PM
accuracy
Aug 30, 2015 09:47 PM
klavender1
Aug 15, 2015 01:51 PM
tobylab
Jul 12, 2015 12:53 PM
