Premium gas vs. Regular Gas
Old Aug 12, 2003 | 09:01 AM
romus's Avatar
Why use premium gas when regular will do?
By James R. Healey, USA TODAY
Link: http://www.usatoday.com/money/autos/...emiumgas_x.htm
Marti Mayne once fueled her low-octane Subaru with high-octane gas. Not now. Premium-gas prices "went sky high, and now I just use low grade" to motor around Yarmouth, Maine, where she runs a marketing business.
When prices dropped earlier this year, she stuck with cheaper fuel because "I don't think that my car runs any differently on high, medium or lower grade."
She's right. Engines designed for regular fuel don't improve on premium and sometimes run worse. And today's engines designed for premium run fine on regular, too, their makers say, though power declines slightly. (Background: About Octane ratings)
But premium lovers are passionate. "I would simply curtail driving rather than switch grades," says Bill Teater of Mount Vernon, Ohio, who puts high-test in both his Cadillacs, though only one recommends it. He's sure both the DeVille and the Escalade run rough and lack pep on regular.
Prejudice and preference aside, engineers, scientists and the federal government say there's little need for premium.
When fuel's cheap, motorists are willing to pay 20 cents or so more for premium. But as gas prices sneak back up, the mental wrangle begins anew over whether it's OK to burn cheaper, regular-grade gas.
AS PRICES RISE, CONSUMERS
SHUN PREMIUM GAS
Average price of a gallon of premium gasoline:
1993 $1.30
1999 $1.36
2002 $1.58
20031 $1.80
Premium gas share of all gas sold:
1993 19.9%
1999 16.8%
2002 13.5%
2003 12.1%
The answer almost always is yes.
"I personally use regular even though my owner's manual says you'll get better performance with premium," says Lewis Gibbs, consulting engineer and 45-year veteran at Chevron oil company. He's chairman of Technical Committee 7 on Fuels, part of the Society of Automotive Engineers (SAE) Fuels & Lubricants Council. Gibbs knows gas.
"My wife runs midgrade (89 octane) in her car, and it's a turbocharged engine" meant for 91-octane premium, he says.
Premium — gasoline having an octane rating 91 or higher — is just 12.1% of sales this year, down from 13.5% in 2002, when it was 22 cents a gallon cheaper, and well below the modern high of 20.3% in 1994, when it was 49 cents cheaper, according to industry and government data. Despite the allure of premium, once they abandon it, most motorists don't come back, the data suggest.
For every dime increase in the price, sales of premium gas drop 1%, Bob Johnson, general manager of gasoline and environmental services for the 7-Eleven chain, figures, based on data back to 1998.
The main advantage of premium-grade gas is that it allows automakers to advertise a few more horsepower by designing and tuning engines to take advantage of premium's anti-knock properties. But auto engineers generally agree that if you use regular in a premium engine, the power loss is so slight, most drivers can't tell.
"I go back and forth, and I'm hard-pressed to notice" whether there's regular or premium in the tank, says Jeff Jetter, principal chemist at Honda Research and Development Americas. He drives an Acura designed for premium.
Import brands, especially, use premium fuel to distinguish their upmarket models. Most Toyotas, for instance, are designed to run on regular or midgrade, while the automaker's Lexus luxury brand prefers premium. Same with Honda and its Acura luxury line.
"Generally, the more expensive the vehicle, the higher the expectation for performance and the more the customer is willing to pay for fuel," says Pete Haidos, head of product planning for Nissan in the USA.
Actually, the price debate is nearly worthless. At 20 cents more for premium, pumping 20 gallons of it instead of regular would cost $4 more. Annually, that's a difference of $171 for a vehicle that averages 14 miles per gallon — as some big sport-utility vehicles do — and is driven 12,000 miles a year.
Gasoline retailers and refiners like high-test because it's more profitable than regular-grade gas is. The retailer paid about 8 cents more for the premium you pay 20 cents more for — though that margin can swing wildly. Refiners make a few cents a gallon more on premium than on regular when they sell to wholesale distributors.
As long as it's clean
Profit is meaningless to the modern engine, which, regardless of what's specified in the owner's manual, hardly cares what you use — as long as it's clean.
Today's engines use highly evolved versions of a device called a knock sensor to adjust settings automatically for low-octane gas. And more engine control computers have adequate memory to allow separate sets of instructions for various octanes. The engine control computers keep pushing to maximize performance on whatever grade of fuel is used.
Extreme pressure inside the cylinders causes knock, which is the sound of the pistons literally rattling inside the cylinders. Too much too long can damage the engine. A little now and then won't.
The only modern engines that should really need premium are those with superchargers, which force-feed fuel into the cylinders. "You're driving along and just tramp the gas and the knock sensor cannot sense the knock fast enough in some cases," because the supercharger boosts pressure so fast, says Bob Furey, chemist and fuels specialist at General Motors.
Burning regular when the owner's manual specifies premium won't void the warranty, nor damage the engine, even the most finicky automakers say. "You're giving up perhaps just a little bit of performance that a customer wouldn't really even notice, it's so slight," says Furey.
Automakers say they don't test premium engines on regular to check the difference, but some auto engineers estimate that power declines roughly 5%.
"We can't guarantee the vehicle will perform as specified if other than premium fuel is used," says Mercedes-Benz spokeswoman Michelle Murad. All U.S. Mercedes engines specify premium.
All Porsche engines are designed for premium, too, but it's not available everywhere. "Our cars must be able to drive all over the world, and so we are able to run on regular," says Jakob Neusser, director of powertrain development at Porsche's research and development center in Weissach, Germany. "You don't have to feel that a mechanical problem or anything else will happen" using regular gas, even in the highest-performance, regular-production Porsches.
Premium, in fact, sometimes is worse fuel than regular. It resists knock because it's harder to ignite than lower-octane fuels. As a result, some engines won't start as quickly or run as smoothly on premium, notes Gibbs, the SAE fuel expert.
High-test does have a potential fuel economy benefit. It is slightly denser than lower-octane gas, meaning there's a little more energy in a gallon. But the small difference is hard to measure in real-world use, and that same density can contribute to undesirable buildup of waste products inside the engine.
No data show that engines designed strictly for regular run better or longer on premium.
The Federal Trade Commission, in a consumer notice, emphasizes: "(I)n most cases, using a higher-octane gasoline than your owner's manual recommends offers absolutely no benefit. It won't make your car perform better, go faster, get better mileage or run cleaner."
There is "no way of taking advantage of premium in a regular-grade car," says Furey.
"There is no gain. You're wasting money," insists Jim Blenkarn, in charge of powertrains at Nissan in the USA.
"No customer should ever be deluded into thinking there's any value in buying a higher grade of octane than we specify," says Toyota's Paul Williamsen, technical expert and trainer.
But premium retains a mystique.
Even Mayne, the sensible Subaru owner who has switched to regular, says she'll buy premium when her neighborhood station has a special price. "It's my perception that I might get better gas mileage or that it might be better for my engine," she says.
"I would stop driving rather than use a lower grade of gasoline," says Andrew Martschenko of Boston, who drives a 2003 Nissan Maxima. Nissan says premium is "recommended" for that engine — automaker code for regular is OK, but you'll only get the advertised power on premium.
If the price difference between regular and premium grew to $1, Martschenko says, "Then I might consider trading down" to regular.
Guilt plays a part
Some people feel almost guilty, as if they are abusing their cars, when they don't burn premium, says gasoline retailer Jay Ricker, president of Ricker Oil of Anderson, Ind., which operates 28 stations. "They go all the way down to 87 (octane), but maybe every fourth tank they put in the good stuff."
Sam Turner has seen the appeal, too. He's president of Favorite Markets of Dalton, Ga., which operates 139 outlets in three states.
He recalls visiting one of his stations during a price war with a nearby station, which had cut the price of premium to just 4 cents more than regular, instead of the usual 20-cent difference.
"A customer was waiting and asked me if I was going to match the guy across the street. I said, 'Yeah,' and he said, 'Good. For 4 cents, I'm gonna buy super.'"
Old Aug 12, 2003 | 12:04 PM
EDGE's Avatar
I've used both 87 and 93 and the only difference I could see was my range dropped and I was filling up more often, with 93 it just seems like it burns more to go the same distance, performance feels the same if not better with 87.
Old Aug 12, 2003 | 01:02 PM
HBoss's Avatar
In the case of the manual saying 87, using premium won't do much for you.
In the case of an engine requiring premium, use it. I don't care if Joe Blow engineer thinks it's all right. Engines designed to use premium fuel (sports cars, some luxury cars, supercharged & turbocharged cars, etc.) need it. What people don't realize is that just because they "don't feel" anything has changed by switching to cheap fuel, it doesn't mean there's nothing wrong.
Performance & fuel economy are just minor possible results of cheaping out on fuel. The untrained ear cannot tell if pinging is occuring & with today's high compression engines, more than likely it will sooner or later. So someone may save a few bucks a tank for now and think they're getting a great deal. I'd put that extra money away for when/if they get blown engine parts due to pre-detonation knocking/pinging.
I have to say, if you're planning on purchasing a vehicle or supercharger/turbocharger that requires premium, be prepared to shell out for fuel now or for engine repairs later.
Old Aug 12, 2003 | 02:42 PM
Eighty7ToyTruck's Avatar
my turbo 4runner spark knocked on low, mid and hi-test... so i ran high with a fuel additive to minimize it... fuels with a higher octane rating burn cooler and faster than lower rated fuels..which is why they resist knocking better...octane rating is also known as anti-knock rating.....so run what the manufacturer tells you to, especially if you have a warranty..
Old Aug 12, 2003 | 03:53 PM
EDGE's Avatar
I believe in using what the owners manual says and for the V8/V6 4Runners it suggest regular and for added performance premium
ctheiss
Sep 8, 2015 09:00 AM
Sarcazmo
Aug 15, 2015 08:22 PM
nonstop
Jul 24, 2015 06:29 PM
smiley52
Jul 11, 2015 05:16 AM
