Power antennas P**s me off
Old May 6, 2004 | 11:05 AM
RnNcklsn's Avatar
My 3rd gen has a power antenna that is not feeling well. It goes up and down with radio on/off, however once I turn the radio on and the antenna has reached full extention, the gears inside the unit grind and grind and grind for at least 10-15 seconds. Not only is it annoying, its embarrassing when the ladies get in. Anyone have any tips or tricks to fix this?
Thanks
Old May 6, 2004 | 11:19 AM
TDiddy's Avatar
Sounds like you need a new antenna mast. There's a plastic strip in there with teeth on it, and it probably broke. I replaced mine recently, its wasn't a bad job. Another popular option is to lose the power antenna and replace it with a Tacoma mast antenna.
Old May 6, 2004 | 11:30 AM
RnNcklsn's Avatar
A new mast sound like the way to go. Thanks for the info Tom. Where can I get that mast from? Where did you find yours?
Old May 6, 2004 | 11:36 AM
TDiddy's Avatar
I got mine at the dealer, although I think you can find some on ebay. I think I paid around $40 or something.
Check the thread below for how I replaced mine.
https://www.yotatech.com/forums/show...656#post272656
Old May 6, 2004 | 12:00 PM
midiwall's Avatar
You can also look at replacing it with a fixed mast. It's kindofa suave' look for The Ladies to admire!
This is the common approach, use the Tacoma whip:
http://www.4runners.org/articles/whip/
This is what I did:
http://www.midiwall.com/4Runner/firestik.html
Old May 6, 2004 | 12:37 PM
4RUNR's Avatar
Guest
Why not just run a wire along the windshield or anywhere else? Unless you live very far from the radio stations... cheaper and no wind noise.
Old May 6, 2004 | 12:45 PM
midiwall's Avatar
Radio antenna's can be tricky things.
While stuffing a coat hanger into your broken mast and twisting it up into a cool semblance of a dragon may technically work, it will tend to produce a lot of IM distortion and develop directional habits (turn left 90 degrees and you drop "All Classic Rock - All The Time!").
There are impedance issues as well which have to be dealt with to get gain of signal and not noise.
Old May 6, 2004 | 07:31 PM
I had the same frustration. Go with the fixed mount Tacoma mast. Its a pricey swap but worth it.
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
delmert
Sep 30, 2015 04:34 PM
Sidherish
Aug 2, 2015 01:42 PM
TDonkey
Jul 26, 2015 10:14 AM
