Power Antenna Toggle?
Old Jun 1, 2007 | 04:54 PM
toy02's Avatar
Has anyone installed a toggle switch to their power antenna to control it going up and down? My antenna's not broken yet so I don't plan on doing a whip mod anytime soon, but I would like to install a toggle to move it up and down when I need it.
I read the whip mod from: http://www.4runners.org/writeups/whip/index.html and saw the diagram of the antenna to the back of the deck. But wouldn't I need to splice the toggle into the wire that leads to the relay switch behind the front dash panel? That's the one that I hear "click" a few seconds after shutting the engine off.
Old Jun 1, 2007 | 04:55 PM
Tofer's Avatar
Sponsor
yep... spliced a simple switch into the blue line coming out of the back of the stereo. it stays down 98% of the time due to sat. and ipod
Old Jun 1, 2007 | 10:26 PM
toy_tek's Avatar
You'll find the search feature quite useful on Yotatech. For example...
Search: antenna
https://www.yotatech.com/forums/show...hlight=antenna
Old Jun 4, 2007 | 10:57 AM
rearviewmirror's Avatar
You can use the manual switch from the LandCruiser, it mounts nicely in the dash.
Old Jun 4, 2007 | 01:04 PM
profuse007's Avatar
Power Antenna black/white + at radio
there are different ways of doing it but this is the simplest way.
cut the wire and use a switch to power the wire that leads to the relay module.
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
delmert
Sep 30, 2015 04:34 PM
Sidherish
Aug 2, 2015 01:42 PM
TDonkey
Jul 26, 2015 10:14 AM
