power antenna mast
Old Dec 29, 2003 | 02:32 PM
Kas888's Avatar
power antenna mast
Well I got a new problem today on my 4runner,antenna mast cable snapped. I took off the antenna , but I think theres around 3 inches of plastic in the motor . How can I get it out?
Old Dec 29, 2003 | 02:49 PM
the4x4runner's Avatar
I had to do this about a year ago. What i did was take the top bolts that hold the fender on( just enoght to get my hand and tools in there). I then unbolted the motor from the frame and had to take the unit that houses the plastic cable apart to take the cable out. I then , with the motor dissengaged from the plastic housingto let the unit that turns turn freely, was able to feed the plastic cable into the plastic housing then attach the motor back up and reattach every thing to the frame. one hint is to curl the plastic cable before trying to feed it in, it will spend most of its life in that curled state and makes it easier to feed in. hope this helps.
Old Dec 29, 2003 | 03:53 PM
Bob_98SR5's Avatar
check out my write up: http://www.4runners.org/articles/whip
Bob
Old Dec 29, 2003 | 04:02 PM
Kas888's Avatar
thanks for the quick response guys. Yotatech is #1
MTL_4runner's Avatar
Make sure to use plenty of grease when you put it back together.
It is not that bad of a job but some of the bolts were a pain.
Old Dec 29, 2003 | 04:53 PM
Bob_98SR5's Avatar
kas,
if you found that helpful, look through the "Tech" section. There are a lot of maintenance and mod writeups that are similar in nature.
Also, your best friend on YT is "Search".
Bob
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
delmert
Sep 30, 2015 04:34 PM
Sidherish
Aug 2, 2015 01:42 PM
TDonkey
Jul 26, 2015 10:14 AM
