Polishing manifolds? 2gen
Old Apr 4, 2004 | 02:26 PM
Doogs's Avatar
Question Polishing manifolds? 2gen
Has anyone tried polishing the internals of a manifold to get a little more performance?.. Is it worth it?
Thanks in advance.
--D
Old Apr 4, 2004 | 02:30 PM
Doogs's Avatar
ohh, let me clarify a bit.
My 94runner "putt-putt" is out getting a valve job as we speak. Can anyone think of mods that I can get done while it is in the shop in order to take advantage of its dissasembled state?.
Polishing the manifold was one of the things I had thought of.
Old Apr 6, 2004 | 06:59 AM
AJatx's Avatar
Porting the inside of say a throttle body and upper intake manifold yields little results. My buddy ported out throttle bodies and manifolds and people thought it helped throttle response and the car felt more "snappy."
Porting the intake and extruding the manifold should help with airflow. Polishing the lower intake manifold near the injectors is not wise since it'll reduce atomization of fuel. You want a bit of roughness in the tract for slight turbalence and atomization.
J
Old Apr 6, 2004 | 09:33 AM
Tahoe666's Avatar
Guest
I have a bored throttle body as well as a ported and polished intake and plenum. I am very happy with the results and I would recomend it to anyone. I experienced substantial gains througout the entire rpm curve. Because of the port and polish, my 4Runner has an impressive power surge between 3200 and 5300 rpm. (it just takes off when it hits 3200). I would also recomend getting headers if you decide to go with the port and polish because all that extra air will need a place to go and the stock exhaust manifolds just won't cut it.
Old Apr 6, 2004 | 12:45 PM
Yoter's Avatar
Guest
while its torn apart have them leave the exhaust crossover pipe out. Have them weld covers over the cross over openings then run a stick of 2.5 exh. down and meet up near the transfer case. Theres some more flow. Or just get headers.
kawazx636
Oct 6, 2021 03:03 PM
puddlepirate
Jul 30, 2016 06:29 PM
Firefightersink15
Nov 23, 2015 10:32 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
the_supernerd
Oct 1, 2015 09:20 PM
