pinions?
Old Oct 28, 2002 | 06:27 PM
bryontro's Avatar
pinions?
What is the differance between 2 pinion and 4 pinion dif? I can't picture it. Also where is the best place to get a third member rebuilt? I have a 92 4 runner and it has high miles but otherwise exc shape. Starting to whine pretty bad and the last guy has already had it retorqued according to the receipts that I got. It has about 30 degrees of free play at the pinion. That seems like a lot to me.
Old Oct 31, 2002 | 12:38 PM
joshik's Avatar
dont realli kno the difference between the two types of pinions, but i kno a place that does gears. i just recently busted my pinion and ring gear. i took it to a place called "performance 4wheel drive" . they did my r&p for $400. $200 for US Gears, not some cheezy "genuine gears" that 4wheelparts performance center sells (made in brazil or something. cheapy!!! ) and $190 for the labor. i took the 3rd member to them though.
Performance 4 Wheel Drive
9817 Park Street
Bellflower, CA 90706
562-925-0028
or try...
Gear Shop
2648 East South Street
Long Beach, CA 90805
562-634-1396
ugh... there was one in hawthrone too. i forgot the name.... ahhhh
Old Oct 31, 2002 | 01:39 PM
Shane's Avatar
Pinion gear is a misnomer in this case, it's actually referring to the spider gears in the differential itself. 4cyl diffs have two spiders, V6 and turbo diffs have 4.
Old Oct 31, 2002 | 02:40 PM
joshik's Avatar
ahhhhh icic cool :pat:
Old Nov 1, 2002 | 07:15 AM
joshik's Avatar
heres another gear places that does is real good.
South Bay TRuck & 4wd
Contact: Frank
310-219-0727
4621 W Rosecrans
Hawthorne, Ca
he works on all 4wd, but he focuses on yotas.
he uses US gears too, but he will install anyone u bring out buy.
Old Nov 4, 2002 | 03:22 PM
bryontro's Avatar
Thanks for the info.. I have found a place here that I have heard good things about. Anyway, I have found out that the 4.30:1 gears are toyota ownly to the tune or $750 for a gear set.
Once I found out if I will need a new set I may just go with new sets on both ends since it will cost the same. I need to now if any one knows of a good site with a couple of formulas so I can figure out how much my cruising RPM will be affected with a 4.10 or 4.88. I have 31X10.50's right now and would like to keep that size but may have to change. It runs about 3100 at 70 mph right now. I don't want it to run much higher than that on the highway. Anybody using the 4.88's with 31x10.50's or 4.10's? Also what is the ratio of 5th gear in the 5 speed? Thanks
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
Odin
Sep 26, 2015 06:56 PM
justdifferentials
Sep 5, 2015 06:52 PM
trailgoat
Aug 13, 2015 05:54 PM
