pinging on 3.4l taco
Old Oct 27, 2004 | 01:16 PM
GoudyMan's Avatar
i have a 2001 3.4l 4x4 xcab 5spd.
anyways, i am getting quite a bit of pinging. I notice if I use 89 then there is not as much pining... but its still there....... any ideas??
do the 3.4l usually ping a little?
thanks
Old Oct 27, 2004 | 01:19 PM
InFlames's Avatar
thanks
Is it supercharged? any other mods?...try using a higher grade of gas.
Old Oct 27, 2004 | 01:33 PM
midiwall's Avatar
Yeah... pinging is never "normal"...
Any chance that you changed your plugs to the "wrong" ones? Maybe something hotter?
Like InFlames asked, are you supercharged? Is there anything else that you've done to your engine - or not done! (dirty air/fuel filter, deckplate mod, ISR mod, ECT mod, etc...)
Old Oct 27, 2004 | 02:09 PM
drabnor's Avatar
thanks
have you changed your spark plugs latley? did you gap them correctly? they should have a gap of .43
Old Oct 28, 2004 | 04:53 PM
Mikey's Avatar
My 98 pings. More lately than normal. I wonder if the gas is getting cheaper? I didn't have many problems with 87 octance before
Last tank I bit the bullet and filled up with 89 octane. Much, much less pinging. It runs much better and smoother too. I guess I just start feeding it 89 at 2.09 a gallon :cry:
Old Oct 28, 2004 | 05:15 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
if your fix is using 89 octane, then try alternating between 89 and 87 each fill-up from about 1/2 tank. see if the minor increase from 87 to about 88 reduces it. it could save you a few bucks.
Old Oct 29, 2004 | 04:36 AM
Dr. Zhivago's Avatar
Away
I would check your MAF sensor. It's probably dirty.
My .02
G
Old Oct 29, 2004 | 05:00 AM
rimpainter.com's Avatar
Running 89 is not a fix. Use it until you can properly diagnose the problem and fix it. Don't just settle for it.
Old Oct 29, 2004 | 05:18 AM
Away
Could also be clogged injectors and/or a dirty combustion chamber. Run some Redline SI-1 thru your tank. Best fuel system treatment ever. You'll find it at good, performance oriented auto parts stores.
Peace.
G
Old Oct 29, 2004 | 06:42 AM
Mikey's Avatar
With mine I know I have cleaned the MAF, did the seafoam thing and all but I still get the pinging. I do have a problem with a rough idle and I wonder if it's connected?
Old Oct 29, 2004 | 06:54 AM
Mikey-
Did you check your plugs?
Old Oct 29, 2004 | 07:01 AM
Mikey's Avatar
That's next on my list, I only have about 20K on them though.
Old Oct 29, 2004 | 09:16 AM
midiwall's Avatar
I see you did the deckplate mod... does the pinging get better/worse with the deckplate in/out? If it changes, then that can help diagnose the problem.
Old Oct 29, 2004 | 05:25 PM
Mikey's Avatar
I can't say I know. I did that over a year ago and never put the plug back in. I liked the power too much. That's an interesting idea though. Maybe I should try and put it in and find out.
nvwiggins
13
Jun 16, 2016 03:05 PM
stanz
Oct 30, 2015 10:33 AM
LCE_Performance
Oct 1, 2015 01:03 PM
Toys4parts
Sep 26, 2015 01:56 PM
Tacoma1313
Aug 17, 2015 05:44 PM
