PCV Valve
Old Nov 24, 2002 | 03:46 PM
PCV Valve
Where the heck is it:confused:
on my 2nd gen 3 litre??
Old Nov 24, 2002 | 04:44 PM
Paul H.'s Avatar
Good luck in finding it. It is on the right side of engine manifold just inboard of your vacuum lines. Very difficult to find and even tougher to replace. I gave up on mine and took it to a shop. Cost me $50.:cry:
Old Nov 24, 2002 | 10:50 PM
butnut's Avatar
Another reason the 2.7 is cake to work on. It's right on top of the valve cover. Took me all of 30 seconds. Spark plugs...ehhh maybe 5 minutes...if I'm really draggin butt. Ya got me beat power wise...oh well.
butnut
Old Nov 25, 2002 | 03:03 AM
Jay's Avatar
Jay
It is located under the intake plenum on Bank 1. Bank 1 implies the side of the engine with Cylinder #1. In this case its the passenger side.
Replacing of the PCV valve on your 3.0L will be tricky. I suggest that if you are seriously gonna replace it, to just plan on taking off the intake plenum. The reason being, the gromett that the pcv valve sits in is going to be hard/brittle if it is the orignal. Making it difficult to get out/in and possibly causing a vacuum leak.
List of part I suggest. ( All toyota parts )
1. PCV valve
2. Hose
3. Gromett
4. Plenum gasket
5. (2) small EFI gaskets ( For cold start injector supply tube )
Good luck.
Jay
Old Nov 25, 2002 | 08:28 AM
Ok..forget it. I'll get it done the next time the timing belt / valve timing are done.
Thanx for all the input
Old Nov 25, 2002 | 01:00 PM
Mohamed's Avatar
ah don't feel bad, I felt the same way.
LotOMiles
Sep 14, 2015 11:45 PM
ac7822
Sep 11, 2015 08:49 AM
Boomer8404
Sep 10, 2015 09:01 AM
idadan208
Sep 7, 2015 09:06 AM
