Old Apr 7, 2016, 12:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Brake Guides
Print Wikipost
parking brake
Old Apr 29, 2008 | 08:08 PM
cosmo's Avatar
parking brake
Anyone ever have the parking brake warning light stay on in their Tacoma?
I can push the parking brake lever in while driving and it briefly turns off, then comes back on again.
Is there any way to adjust the linkage or lever so this does not occur?
It's not really a huge issue, but it sometimes gets annoying.
Old Apr 29, 2008 | 09:33 PM
warriors_03's Avatar
This sounds like its low brake fluid in the master cylinder not a linkage adjustment.
Old Apr 29, 2008 | 09:39 PM
NwRunner's Avatar
I had the same problem.
Go buy some brake fluid and fill your resivoir all the way to the tippy top, problem solved.
Old Apr 29, 2008 | 10:04 PM
DeathCougar's Avatar
Please do not just "fill it up" and forget about it.
Find the problem first. There is a reason the brake fluid is low in the first place, be it from leaking, worn brakes, etc etc.
Find/fix the problem first, THEN fill the reservoir.
Old Apr 30, 2008 | 07:10 AM
x2 on that one...
Old Apr 30, 2008 | 08:13 AM
NwRunner's Avatar
instead of tearing into the car to find a possible problem as deathcougar suggested, fill your resivoir and watch the level. If it stays the same you are fine, as with my case. But if it drops again, then you should look into fixing some sort of brake problem.
jashoeuh
Nov 18, 2024 08:08 AM
skoob
Oct 15, 2015 03:23 PM
romex1
Aug 10, 2015 06:21 PM
terminator
Jul 27, 2015 07:13 PM
CanRunner
Jul 20, 2015 01:29 PM
