Paddle shift 4runner project
Old Nov 30, 2011 | 04:53 PM
Clownmeat's Avatar
Going to attempt to make the auto A340F in my 98 4runner manually shifted via paddles. After turbocharging it I need to have more control over the amount of throttle vs speed without the passing gear/kickdown getting in the way. Also I just like manual transmissions and this is the next best thing without swapping one in. Progress might be slow, but determined to accomplish this.
Old Nov 30, 2011 | 05:00 PM
xxxtreme22r's Avatar
Superscribed.
Old Nov 30, 2011 | 05:05 PM
scuba's Avatar
I've got the popcorn. Who wants some?
Old Nov 30, 2011 | 08:05 PM
Clownmeat's Avatar
After talking with my collaborator over the last week looks like this project is going to happen. Paddles showed up today and he emailed me the first blueprint for the control box. Needs to be built and tested, just need time, which is in short supply.
Old Nov 30, 2011 | 08:39 PM
BoredOutnJackdUp's Avatar
scribed.
Old Dec 1, 2011 | 05:22 AM
Texas_Ace's Avatar
Interested in see how this works out. I would be interested in this if it works well.
It would need to be option for sure, be able to go back into regular mode for normal driving at the flip of a switch.
Also, Someone else to consider taking control over while in there is the lockup converter. I would like it to be engaged in more then just overdrive but I don't think it will stand up to WOT so it would need to be turned off anytime the throttle is above ~25% or the brakes are pressed.
Old Dec 1, 2011 | 05:27 AM
blake.nemitz's Avatar
cool scribed
Old Dec 1, 2011 | 07:06 AM
Clownmeat's Avatar
There will be a 2pdt on/on rocker or rotary switch. Position 1 ECM controlled, position 2 paddle shift.
As far as the lockup, maybe 3 positions, haven't come to a conclusion yet because I will need to road test it and play with it more to make it to my liking.
1. Stock ECM controlled
2. A manual on/off switch
3. Race/whatever mode, under WOT will lock in 2,3,4
Old Dec 1, 2011 | 11:00 AM
Clownmeat's Avatar
This thread didn't have any pics yet, I'm slacking.
Old Dec 1, 2011 | 11:13 AM
Texas_Ace's Avatar
Nice switches, how much were they and where are you going to mount them?
Old Dec 1, 2011 | 11:17 AM
BigBluePile's Avatar
Cool!
Old Dec 1, 2011 | 11:21 AM
Clownmeat's Avatar
$16.13 each, in the steering wheel.
Old Dec 1, 2011 | 12:35 PM
Clownmeat's Avatar
Rough draft, basic idea, just need a flux capacitor.
Old Dec 1, 2011 | 12:48 PM
Clownmeat's Avatar
One week later got a daft done of the circuit.
Old Dec 1, 2011 | 05:38 PM
Clownmeat's Avatar
Colors I chose for the LED's in the gear indicator that will probably go somewhere on top of the steering column or inside the cluster somewhere.
Old Dec 1, 2011 | 06:13 PM
paintthetown's Avatar
I like extra butter on my popcorn. Scribed
Old Dec 1, 2011 | 06:28 PM
Clownmeat's Avatar
You guys may need a couple more buckets of popcorn, but should be done before the end of the year.
Old Dec 1, 2011 | 07:03 PM
cpizzle42's Avatar
One of the engineers for a company I worked for figured out how to do this on a car we built. It was for a GM 4l80 behind a LS3. And we were using a GM performance transmision controller that allowed the manual shifting, controlled by a toggle switch, to switch between manual and auto shifting. But the idea was cool and it worked well in the dirt for engine braking. Great new idea, keep at it man!
Old Dec 1, 2011 | 07:46 PM
BlindfoldMemphis's Avatar
Is there going to be an led for a park or neutral?
Old Dec 1, 2011 | 07:55 PM
Clownmeat's Avatar
No, just the stock ones in the dash. Park, neutral, reverse are not affected by this kind of control. In paddle/manual mode the stock shifter will be put into drive and then select the toggle switch to manual mode, then good to go up and down all you want.
