p0304 code ugh!!!
Old May 1, 2010 | 10:05 PM
SharpStick's Avatar
Yeah, ohm the injector. My bad one was at .018 - you'll know right away.
STICK a fork in it
Old May 1, 2010 | 10:07 PM
SharpStick's Avatar
And don't forget to tune in to my show - Hank Watson's Garage Hour, 6: PM Saturdays on 1170AM. You can log on and listen at KCBQ.com. Dirt, race, off-road. tools, guns, beer. We're doing a DUI show this Saturday upcoming, with promos for the Saddleback Run the next day (May 9).
STICKers for the show are available if you want them - email me your address
Old May 2, 2010 | 11:27 PM
zmbombr's Avatar
what is the correct cylinder numbering? I was told ( by dealer tech and from another thread) the number 6 is driver side all the way back, but that is not what my testing suggests. I pulled all my injectors and sent to be cleaned and tested after all the pre diaogs, I even ohmd them all before and they all tested good (about 14.4-14.2) so I figured the flow test would confirm the number 6 was clogged (had a p0300 and p0306) but the only injector that came back faulty was the 5 (passenger side back) and it was found to be "dripping"
according to somelses thread reference of cylinder numbering:
5 6
3 4
1 2
front
is this correct numbering?
if so could the code be wrong or if not then the misfire has yet to be found?
Old May 3, 2010 | 11:04 AM
brian2sun's Avatar
That is the correct cyl. order and the code is almost certainly not telling you it's the wrong cylinder (I've never heard of that happening). Your testing would lead me to believe it's not an injector, but a spark/wiring, valve, or hg issue.
Old Nov 14, 2010 | 08:38 PM
  #25
BigBallin410's Avatar
Exclamation Have same Code (304)
my check engine light came on almost 2 months ago, i have a 97 2.7 Runner and the already underpowered engine is even more sluggish and a full tank doesnt even last me a week these days. wires and plugs were replaced recently and i just checked the plugs to make sure they werent the cause. thinking its the fuel injector but not sure. any ideas? and how much would it usually cost to replace injector/s?
Old Nov 14, 2010 | 09:48 PM
  #26
zmbombr's Avatar
miss fire due to bad valve
Swap the coils around and reset the computer and see if the misfire comes up under a different cylinder. if so its your coil. if it still codes misfire on the same cylinder take it in for a compression test. I did all the other diognostics and eventually found a bad valve after the compression came back low. there are some home test tricks for this as well, I am not experienced with it but it involves a dollar bill and observing the "suction" stroke of the valve which indicates impoper seating and a worn valve.
Old Apr 12, 2014 | 11:27 AM
  #27
Nitebishop's Avatar
Looking at replacing the #4 fuel injector. What is the easiest way to get it done without taking whole top part of the motor apart? Can I get by with the throttle body removal only?
Old Apr 14, 2014 | 09:55 AM
  #28
zmbombr's Avatar
for the number 2, 4 and 6 you have to remove the intake plenum, no options there. it aint too bad. you can remove the whole plenum, upper and lower, by just removing the 2 middle bolts and 2 end nuts that holds the plenum to the intake head. then there is one more bolt in the middle underneath the upper plenum. you can lossen this enough to get the whole plenum off without taking it aprt into two pieces.
I would ohm the injector and if good swap it with another cycliner to see it you still misfire with it. unless you can flow test it or dont mind blowing some $$. This will save you from having to order an injector untill you are sure you need it.
Also you should compression test beofore/after injector troubleshoot. bad compression is most likey due to valves needing attention and is good to know. both tacos I have had needed valve work over 200kmiles. if these are bad for long enough you can damage your head too. this was discovered with misfires after futing with injectors that were all good.
I reuse the plenum gaskets as long as no major blemishes. Mkae sure you use new orings on the old injectors when swapping them around! a tiny touch of oil or even gas will help slide them in.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
