Overheating Mystery??
Old May 17, 2004 | 10:52 AM
Flamedx4's Avatar
If you look at a thermostat, it's really restrictive. Even when open, the body restricts the flow a lot. Stuck open would cause the engine to warm up slowly in the morning, but it would probably run fine and get you home. You'd probably notice with a stuck tstat that the temp gauge fluctuates where normally it stayed precisely planted. The proper thermostat is absolutely necessary to keep the engine in the correct temperature range for efficient combustion. People keep doing things like putting in 165s and then have other problems show up down the road. It's a simple device but it's very important.
Old May 17, 2004 | 11:03 AM
Flamedx4's Avatar
A few pics are at www.pcez.com/~pcollins
Old May 17, 2004 | 01:17 PM
DavidA's Avatar
That has to be one of the most beautiful interiors on a Toyota PU that I have ever seen. Awesome man. How long did it take you to customize it like that?
Just beautiful....
Old May 17, 2004 | 02:06 PM
My99's Avatar
For the record, running with no thermostat will nearly always overheat. The coolant has to stay in the radiator long enough to shed heat, and removing the obstructive thermostat lets the water flow too fast through the radiator so it's still hot when it returns.
Never heard of this before. I've heard the opposite many times, that the coolant will never reach normal operating temps. The time it spends in the radiator is a lot longer than it spends running through the block.
Old May 17, 2004 | 02:19 PM
  #25
mt_goat's Avatar
Wow, very nice! What did you use to paint the interior plastic?
ladybugRC
458
Aug 21, 2020 10:41 AM
Bourbonblues
Dec 15, 2017 05:43 PM
nvwiggins
13
Jun 16, 2016 03:05 PM
alexcarey
Oct 14, 2015 06:05 PM
LotOMiles
Sep 14, 2015 11:45 PM
