Outer CV Boot Clamp (Help Needed Tonight)
Old Oct 22, 2004 | 05:38 PM
Jacob's Avatar
I have the axle out on my 97 4Runner and am putting the boots and clamps back on. The outer boot has clamps that look like they need a special tool to crimp the band tight. This is a kit from the dealership. The inner clamps look like you simply bend the end of the band down and bend the tabs over. These are the same type bands as the ones that were on the old boots. Can anyone help me with ideas on a method to tighten the outer ones. Thanks for your help.
Old Oct 22, 2004 | 06:12 PM
Hyperlite's Avatar
niddle nose plyers, pull the wire as tight as you can and then hit the nob in the hole the fold the tabs over.
Does anyone know where to get replacement clamps?????
Old Oct 22, 2004 | 06:13 PM
snwbrdpunk16's Avatar
The dealership told me the only way to clamp it was with the "special" tool. They told me i could rent it at napa, or other places like that. but i just had the dealership do it so it was on waranty.
Old Oct 22, 2004 | 06:23 PM
Hyperlite's Avatar
niddle nose and a screwdriver.
Old Oct 22, 2004 | 06:39 PM
toy283's Avatar
I've got the correct tool for the job. You're not anywhere Denver, are you?
Old Oct 23, 2004 | 08:27 AM
Jacob's Avatar
Thanks for your replies. I ended up getting a bull nose type wire cutter that looks like the special tool. It worked fine.
Old Oct 23, 2004 | 09:30 AM
Flamedx4's Avatar
Any auto parts store has replacement universal clamps for about $1 each. They work perfectly with no special tool.
Old Oct 23, 2004 | 06:22 PM
User 051420's Avatar
HAH..I got those "universal" clamps and a little tool thing just yesterday. For the life of me, I couldn't get the clamp even remotely tight...it would just snap. Today, I picked up a hose clamp, and it works like a charm.
Old Oct 24, 2004 | 12:06 PM
Flamedx4's Avatar
Never needed any tool other than needle nose pliars. Don't try to pull them so tight - the boots 'snap' into grooves, all the clamps do is keep them from popping out. They only have to be snug. I used plastic wire ties on a car I once had (%$#& Audi) and they were fine for more than 80,000 miles...
Unless the hose clamp fits into the groove for the bands, it will likely 'walk' off of there pretty quickly.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
Road Bull
Oct 10, 2015 04:55 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
mickyd9990
Jul 6, 2015 09:01 AM
