Optima Yellow Top D51R - Anyone with experience???
Old 06-22-2003, 12:37 PM
TRD 4RNR's Avatar
http://www.1st-optima-batteries.com/
Has anyone installed the D51R Yellow Top Battery?
It's a reverse post deep cell battery that 9" tall and should fit without the hight spacer. However it's only 5" wide instead of 6.8
Any thoughts ?
Old 06-22-2003, 12:53 PM
butnut's Avatar
Sorry bro, I don't have an answer, but I do have a question. I know a lot of guys here are using the Optima. I believe the Orange top was the one with the correct terminals. I saw Red and Blue tops at Costco yesterday. Can anyone list the model # of the Optima that fits the 3rd gen and if that spacer lift is needed? My battery may be going soon. Thanks guys.
Old 06-22-2003, 02:15 PM
TRD 4RNR's Avatar
Well, the 34R has the "reverse" terminals and that's what you want unless you want to replace the battery cables.
The 34R is a red top (no longer orange) and not the yellow deep cell.
You will need to get (or make) a height adapter if you want the battery to be the same hight as the old one and be held down properly by the factory bracket.
Old 06-25-2003, 05:35 AM
transalper's Avatar
I put in a Yellowtop a while back. I used a 1" board for a spacer to raise it up a bit so I could use the stock mounting bracket. I bought a short positive battery cable to extend the positive. The big negative wire was long enough, but I had to extend the short ground wire that connects to the body. Here's a pic:
westonian18
05-01-2020 06:38 AM
jasonty
41
12-23-2018 01:00 PM
Flossy
08-05-2015 05:14 PM
80Truck
07-24-2015 03:12 PM
Quick Reply: Optima Yellow Top D51R - Anyone with experience???
