Optima Battery in 3rd Gen 4Runner
Old Oct 2, 2005 | 08:45 PM
xcmountain80's Avatar
Yeah but I think I got a bad battery it seems like its dead as hell eveytime it sits for more than 6 hours!! Like so dead it wont even turn over just clicks then 2 minutes later has barely enough juice to turn the rice machine over and then it starts ... any ideas?
Aaron
Old Oct 3, 2005 | 01:57 PM
4runner4middie's Avatar
I just put my new optima in, doesnt look like it solved my stereo problem, but i'll see after i drive it around for a while... if anyone has any suggestions they would be greatly appreciated.
Old Oct 3, 2005 | 03:00 PM
Lone4runner's Avatar
why are most people only using a red top? what about the yellow and blue?
Old Oct 4, 2005 | 01:06 PM
sandcrawler's Avatar
red is starting only.
blue is starting and deep-cycle; intended for marine use, but will work on autos.
yellow is starting and deep-cycle, too. but more for commercial applications.
personally, i'm getting a bluetop. living right on the ocean i think the marine functionality is a good thing; metal corrodes in no time around here.
Old Oct 4, 2005 | 01:14 PM
  #25
so whats the point of getting a red as opposed to the regular batteries. I guess i'm not sure what the deal is with these batteries
Old Oct 4, 2005 | 01:24 PM
  #26
technically i think the red tops are the "regular batteries"
blues and yellows are deep-cycle to support lots of accessories/running things without the engine going/draining it down...
Old Oct 4, 2005 | 02:26 PM
  #27
sounds like the blues have it then
Old Oct 7, 2005 | 04:34 AM
  #28
Just so happens that since these are gel cell and wont leak you can mount them in any positin, like sideways giving you 4 additional surfaces to use as the bottom of the battery making you ideal moutning location better. As for tought they are all pretty damn tough shock resistant and what not. Making then better than the leakable not so many options in mounting type of liquid acid batteries.
Aaron
Old Nov 1, 2005 | 05:20 PM
  #29
By chance has anyone else run into the issue of total destruction with a new yellow top in your 3rd gen?
Old Nov 1, 2005 | 06:30 PM
  #30
? huh ??
Old Nov 14, 2005 | 06:11 PM
  #31
As I said before my runner killed a new yellow top in 2 days w/o running any acessories, has anyone had any problems with yellow tops?
Aaron
Old Nov 14, 2005 | 06:24 PM
  #32
LOCKnGO's Avatar
Aaron
I've had a yellow top in my civic for almost a year with no problems yet.
GO Here OPTIMA
Old Nov 14, 2005 | 06:46 PM
  #33
I meant in a 4 runner...
Aaron
Old Nov 14, 2005 | 07:07 PM
  #34
LOCKnGO's Avatar
The vehicle is irrevilant, the yellow tops are all built the same. Hell a few weeks ago I left my dome light on all night and drained the battery completely. A few hours on the charger and all is welll.
It sounds like your charging system is messed up. Go get your charging system and battery tested, Advance Auto Parts does it for free.
Old Nov 15, 2005 | 08:10 AM
  #35
Did that I think it may have been a bad battery but the date stamp on manufacture date was 04. Since then I put my Stock panasonic battery back in and hava had no problems since, but seeing as how the toyota isn't even a selectable option on Optima site I wondered.
Aaron
Old Nov 15, 2005 | 02:47 PM
  #36
... seeing as how the toyota isn't even a selectable option on Optima site I wondered... Aaron
the vehicle the optima goes into shouldn't make any difference...nothing showed up on the elec system test?
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Jdgarrison
Oct 1, 2015 05:22 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
