Optima-34R or 51R?
Old Apr 10, 2004 | 06:28 PM
dragr1's Avatar
Optima-34R or 51R?
I'm looking at a new battery and I can't decide b/n the Red Top Reverse post 34R and Yellow Top reverse post 51R. I have a winch that may get occasional use and will probably have onboard air someday, but most of my miles are on the highway or around town unfortunately. According to the dimensions the 51R Yellow is the same height as my stock battery, so I'm leaning towards it b/c I think it will fit with no modifications and it's only $4 more than the red top. It only has a 12 month free replacement warranty though, where the red top has a 36 month free replacement and another 36 months pro-rated.
Anyhow, what do you guys think?
Old Apr 11, 2004 | 07:50 AM
tms2u's Avatar
Since you have a winch, I'd go w/ a yellow top. Its a deep cycle, so it wont hurt it if you drain it. Drain a red top too often and you'd be using that 36 mo warranty sooner than you'll want
Old Apr 12, 2004 | 05:13 PM
dragr1's Avatar
I talked with Optima tech support today and the Yellow Top 51R is designed for Honda's and they said it doesn't have enough cranking amps for the 3.4 Toyota. So, now I'm back to the Red Top 34R or custom cables and a yellow top.
Old Apr 12, 2004 | 05:18 PM
shazaam's Avatar
Don't need custom cables with a yellow top. I extended my positive lead wires with a piece of copper pipe. .99 cents
Old Apr 12, 2004 | 05:34 PM
dragr1's Avatar
You had pics of this somewhere didn't you?
Old Apr 12, 2004 | 05:39 PM
shazaam's Avatar
yeah I did, I looked for them, but now I can't find them. Basically cut a 2" round piece of copper pipe. Then place it under a board and hammer it into a flat piece of copper. drill one hole on both ends. Bolt on end to the cable, and the other end to the little piece that attaches to the battery terminal. Thats it.
Old Apr 12, 2004 | 05:41 PM
shazaam's Avatar
You have to bend the bar that holds the battery in place too, but thats easy. and the whole already exists in the frame rail. So just put a nut and bolt in it and your done.
Old Apr 12, 2004 | 05:45 PM
dragr1's Avatar
Yeah, I remember this now, post the pics if you find them.
Old Apr 12, 2004 | 05:51 PM
shazaam's Avatar
Not my set up .. but mine looks like this.
Old Apr 12, 2004 | 05:54 PM
dragr1's Avatar
That's the pic I saw. What model # Yellow top you have?
Old Apr 12, 2004 | 05:59 PM
shazaam's Avatar
D34/78-950. It worked for about two weeks, but then it wouldn't turn the engine over. So I think I might have a bad one, haven't had a chance to go have it tested, but I think I will go check it out tomorrow.
