OME Lift Installed, Driveshaft Vibration??
Old Feb 12, 2005 | 09:19 PM
ugadawg95's Avatar
99 4Runner 2wd
87,000 mi
I installed OME 891's with the N86 Shocks in the rear last night and had to run out for a quick second to the store with just the rear lifted. I noticed the vibration after I got over 50 mph and let off of the gas. I figured it was just because the angle of the driveshaft was so great that it was grinding on something and it would go away after I finished the front up today. Well I got the front completed and took it for a test run. Let me just say that this is a 1000% increase in ride quality over the stock suspension! Except for this vibration, which remains after the full lift. I feel it in my feet after I let off the gas. I have read about the angles in the u-joints causing the driveshaft to vibrate. I just am uncertian where to start to troubleshoot this problem.
1) I was going to try and lubicate the u-joints to see if this helps. I can not find any fittings on the u-joints to lubricate. Can anyone point me in the right direction on this.
2) Have someone inspect the u-joints to they are not damaged/worn out.
Does anyone in the Atlanta area know of someone they would recommend?
3) I have read of folks lowering the trans crossmember https://www.yotatech.com/forums/show...72&postcount=9 to fix the problem. Has anyone else had to do this?
It is not really a terrible vibration, but I don't want to damage anything either. Anyone have any input. Thanks.
Old Feb 13, 2005 | 03:47 AM
Bighead's Avatar
Lubing Your Driveshaft
The only vibration I have had and fixed was U-Joint related. I had my 4Runner lifted for about 3 years before that happened. I was able to feel the wear/notch in the rear U-Joint when I turned the driveshaft by hand; pretty noticable.
Old Feb 13, 2005 | 04:54 AM
MTL_4runner's Avatar
Someone had mentioned at one time that the 2wd versions had permanently lubed u-joints.
You should also check the u-joints for damage/wear.
If you have a panhard bar you should check that angle and get a drop if needed to correct the angle.
Old Feb 13, 2005 | 08:26 AM
Albuquerque Jim's Avatar
It is my opinion that lifting without dropping the panhard bracket or getting a longer rod will cause driveline vibration. Talk to Schaefer he can fix you up.
Old Feb 13, 2005 | 10:25 AM
ugadawg95's Avatar
Thanks Jim, as ususal I already have Steve fabbing a bracket for me. Should be here later this week. I figured since it happened after the rear lift, it was probably tracking wrong and this could have been the cause. I just wasn't sure. Hopefully this will take care of it. Thanks again Jim!
Old Feb 13, 2005 | 11:05 AM
Geez....no credit.
Hope you get it fixed.
Old Feb 13, 2005 | 02:27 PM
Randomness's Avatar
Is this driveline vibe problem only for 3rd Gens?
Old Feb 13, 2005 | 02:56 PM
ugadawg95's Avatar
Originally Posted by MTL_4runner
Geez....no credit.
Sorry I left you off my thank you list Jamie. Props to being on the right track...no pun intended I ALWAYS get good advice on this forum. Folks like you make yotatech what it is
Old Feb 13, 2005 | 03:07 PM
Paul H.'s Avatar
Must be, my 2nd gen has no vibration problem after installing rear OME coils and no panhard bracket.
Old Feb 13, 2005 | 03:08 PM
ugadawg95's Avatar
Not sure, but it is a problem on this 3rd Gen
Old Feb 13, 2005 | 03:29 PM
Randomness's Avatar
Ok...Cuz I have some kind of vibe after the OME coils, but I think it might be my wheel bearings, I just don't know what feels like driveline vibes, and what feels like shot wheel bearings
Old Feb 15, 2005 | 05:30 AM
ugadawg95's Avatar
I have been talking to Steve Schaeffer and he told me that he has never heard of driveline vibration issues on a 2wd 4Runner. Has anyone else experienced this when lifting a 2wd? I have TRD Coils in front with N91S and 891/N86 out back. Like I said before, the vibration started after the rear lift. I am trying to find this noise but have been unsuccessful. Anyone????
Old Feb 17, 2005 | 09:53 AM
ugadawg95's Avatar
I went to a "driveline specialist" today. I was rather dissapointed. He did not want to take a test ride to feel the problem I have been having. He said the angles on the driveline are probably off because of the lift...(sarcasm on) ya think? (sarcasm off) He said I should contact OME directly and ask them what to do. I got the feeling he didn't want to try and troubleshoot my problem so I just cut it short and left. I guess I'll just have to live with it or take the lift out, which I really do not want to do. I was hoping this would be a common enough problem that I could find some help from some of the local shops. Guess not
Old Feb 17, 2005 | 10:00 AM
Have you gotten a drop for the panhard bar yet?
You could try just removing the rear springs, try the stock ones and drive it to see if there is still a vibration.
If it is gone, that would be a good pointer that the angle was indeed the cause and not something else.
Old Feb 17, 2005 | 10:17 AM
BruceTS's Avatar
I have all sorts of angle on my rear driveline, more so than most, and as long as I keep it lubricated there is no vibration due to the shaft. Over lubricating the slip joint will cause it to vibrate as well, as for needing a drop bracket to prevent vibration???? i'll just say I still don't have one, not because it's not needed, but because I have other plans on my rear suspension, in the works.
Old Feb 17, 2005 | 11:10 AM
ugadawg95's Avatar
I have one ordered from Steve. Should be here this week. I know it is a result of the lift. I put the rears in and drove the truck before I put the fronts on...that is when it all started. I even re-did the rear making sure everthing was straight. No change. It is noticeable in my feet around 40-50 moh. It sounds like grinding as a result of the vibration. Thanks Jamie.
Well I got better than 3" of lift on the 2wd suspension. Unfortunately there is no lubricating the driveshaft on a 2wd In fact I can not find where I can lubricate anything in the driveline. I hope the panhard drop fixes the problem...somehow with the luck I have been having I doubt it Thanks Bruce!
Old Feb 17, 2005 | 12:36 PM
The panhard drop may or may not fix it but it will keep you from having other problems resulting from that much lift. It could also be a wheel bearing as well so that is also something to look at. I would try the stock springs again to see if that causes a reduction in the vibration. If you are actually hearing a grinding sound at speed you may need to use a chassis microphone setup to pinpoint where exactly the noise is coming from....which should eb the cause of this vibration as well. It is a tough one.
Old Feb 17, 2005 | 04:09 PM
Good news...I went to a different diff shop and Houston we have a problem. The panhard bar is in fact the problem. The rear axle shifted to the passenger side quite a bit. Not easy to see with the naked eye, but the mechanic set up a laser down each side of the runner and low and behold there inlies the problem. The vibration is a direct result of the tracking of the rear axle and the diff is off just enough to give a slight vibration. He also told me he would weld my bracket for me when I get it. He was very good, much better than the "specialist" Anyway I feel better knowing that I am closer to getting this fixed I will update the thread upon completion. Thanks to all that helped!
I figured, especially on a 2wd the angle might be extreme but I haven't heard any complaining of a driveshaft vibration so I had some reservations about saying a panhard drop would fix it for sure. Let us know how it turns out.
Old Feb 17, 2005 | 09:27 PM
AUJWE
Guest
Posts: n/a
My 2000 2WD has been lifted close to 3 inches since March of 2003, and I don't have the problem that you mentioned. Granted, I could probably use a panhard drop bracket b/c I'm sure mine is a little off too but I dont' have the problem that you listed. Unless I am too used to it or too dumb to notice. Both are a possibility. I definitely have vibrations, but I am pretty sure that they are caued by my tires as they are always better after a rotation. Mine also shakes a lot less since I removed my brush guard. Maybe I should look into getting a panhard bracket. Keep us posted.
Old Feb 17, 2005 | 09:47 PM
keisur's Avatar
I'll be anxiously awaiting the verdict as I don't buy the idea that it's being caused by the panhard. I would say you have a bad ujoint and lifting made it more apparent. I know I've got a bad joint, the one at the companion flange in the rear because when i pulled the shaft it binds and doesn't rotate freely, it also clinks when taking off and changing direction.
