OME 881 / 906 Setup
Old May 23, 2008 | 09:06 AM
gilby4runner's Avatar
Looking at the same set up! I have the identical runner and i hate that it sits lower than most. Good Job!
Old May 23, 2008 | 09:25 AM
hillbilly's Avatar
Originally Posted by 4biker
I had the exact same results. After driving for a while with the new tires, I've gotten 20mpg at best (highway), and 17.5 (all city) on my last tank, taking it really easy on the skinny pedal. I always seem to be in a hurry while driving my wife's car though.
My understanding is that if you pair the OME springs with the OME (comfort) shocks, it will ride comparably to stock (probably better). I have OME springs with stock shocks, and it's a little stiff for my liking. Stock springs with OME shocks would probably give you a spongy ride (just for comparison). If anyone knows better, please correct me.
Keep in mind that moving up to 265/75 changes your speedo's accuracy slightly as well. Theoretically with 265/75, when your speedo shows 65mph, you're actual speed is likely 66-67mph. So essentially your actual mileage will be somewhat more than what your speedo reflects.
Old May 23, 2008 | 10:34 AM
4biker's Avatar
Yeah, I know. My posted mpg's account for that.
Nine years of science in college has to come in handy somewhere.
Old May 23, 2008 | 11:09 AM
4biker's Avatar
[hijack]
Sorry about the double post, and Especially sorry about the flagrant thread hijack, but I just ran across this tire size calculator - probably the best I've seen. http://www.rims-n-tires.com/rt_specs.jsp
Total circumference for a 265/70/16 (notwithstanding the differences in tread depth and casing specs from tire to tire) is 96.2", whereas the circumference for a 265/75/16 is 99.4", making the 75 profile 3.3% greater than the 70. If your speedo is set to the 265/70/16 tire, when it reads 65mph, you will actually be traveling 67.15mph. 75mph translates to 77.48mph.
I thought the difference was more like 5%, but that was just a guess. My speedo is off regardless, so I just put it at or below the speed limit, and I'm usually speeding anyway.
again, 4biker= (and not even the best nerd )
[/hijack]
Old May 25, 2008 | 10:08 AM
  #25
cocoslow's Avatar
Here's another tire size calculator that tell you the speedo impact as well as the different dimensions.
http://www.1010tires.com/TireSizeCal...?action=submit
kawazx636
Oct 6, 2021 03:03 PM
ZGjethro
Jun 7, 2017 11:04 PM
A2theK
Oct 14, 2015 07:10 AM
4runnerFireman
Sep 29, 2015 06:24 AM
Keithstoyota
Sep 27, 2015 07:29 AM
