Oil pan gasket
Old Dec 10, 2003 | 01:37 PM
dropcivic's Avatar
Oil pan gasket
How hard is it to replace the oil pan gasket? I was looking at doing it on my truck but it seems that a)you have to pull the engine or b)drop the front diff. Anybody got any tips?
Its a 93 4runner SR5 with 88000 miles on it.
Old Dec 14, 2003 | 10:34 AM
dropcivic's Avatar
Any help?
Old Dec 14, 2003 | 11:21 AM
EDGE's Avatar
Is it leaking, and if your under their you just can't take it down, i've got an 03 so a 93 is far gone
Old Dec 14, 2003 | 11:49 AM
Babypig's Avatar
It's gonna be a tough thing to replace. The diff in front is in the way. So you'll have to lift the engine quite a bit or drop the diff. I'll lokk for some more info and get back to ya.
Old Dec 14, 2003 | 12:01 PM
Babypig's Avatar
yeah its gonna be ugly. Dropping the diff is the easiest(sic) way to do it. How bad is it dripping. You could always undo the pan and let it down as much as possible the use gasket maker of the proper type on it. I don't envy you having to do this job.
Old Dec 15, 2003 | 01:07 PM
dropcivic's Avatar
Preety bad. Dropping the diff is what i was thinking.
Old Dec 15, 2003 | 01:51 PM
44Runner's Avatar
Gasket? Is there even a gasket there? If there is, I wouldn't put one back on. Go with some high quality Toyota FIPG...
Old Dec 15, 2003 | 03:38 PM
95_4X4Runner's Avatar
That's what I was thinking, there probably is no gasket.
Are you sure absolutely sure it's leaking from there?
Maybe try washing the engine with that gunk engine cleaner and a stiff brush, and verifying that's where the leak is coming from.
If you're at 88K miles, have you changed the timing belt? If not, maybe change the belt, and replace the front main, oil pump and camshaft oil seals while you're at it, maybe that'll help.
Old Dec 15, 2003 | 04:42 PM
Los Gatos?'s Avatar
Cost $130 to have done at the dealer, that's all I know.
Old Dec 15, 2003 | 08:03 PM
According to my mechanic, there is a gasket and it is supposedly a pain to get to it. I have a leak in the same place and it's supposed to cost about $350 to work on it.
Old Dec 15, 2003 | 09:40 PM
Los Gatos?'s Avatar
$130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer $130 at the toyota dealer
Old Dec 16, 2003 | 05:47 AM
Babypig's Avatar
I think that the guys are right. After 91 they stopped using gaskets on the oil pans. There is unfortunatley no easy way to solve this unless you drop the diff or take it to a shop. The FIPG is what I was refering to before. Vey good product. Use it sparingly if you do it yourself.
Old Dec 16, 2003 | 12:09 PM
dropcivic's Avatar
Thanks Gatos, Babypig, and everybody else.
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
