Oil deposits in throttle body?
Old Apr 14, 2005 | 01:51 PM
skm's Avatar
skm
Post Oil deposits in throttle body?
While off-roading last weekend at the eastern Idaho sand dunes, I managed to tow out a full-sized Chevy Suburban with a dead engine using my 94 4Runner. Just like to mention that to all those who think the 3VZE doesn't have any muscle.
Anyway, while poking around in the engine last night I removed the air cleaner hose from the intake manifold, and noticed what looked like engine oil in the throttle body. It was rather dirty, so I wiped it out with a rag. Im just curious to know if this is normal or bad? I also found oil in the air flow meter attached to the air filter. Is it coming from the breather hose thats attatched to the drivers side cam cover? This is the first time Ive seen this since buying the truck 2 years ago. I do have a K&N FIPK installed (which was a waste of $$$ btw). Could it possibly be some oil from the filter? I have used the cleaner kit on this filter before. Any ideas?
Nick
Old Apr 14, 2005 | 01:56 PM
terryjmatthew's Avatar
Most likely oil from the filter. Not sure about K&N, but Amsoils come way over-oiled from the factory.
Old Apr 14, 2005 | 03:14 PM
jimbo74's Avatar
its oil from the filter or backspray from the pcv..... when the pcv vents back into the intake stream to aid in combustion, it carries oil in vapor form.... most liekly the source of accumulated oil....
Old Apr 14, 2005 | 03:17 PM
rimpainter.com's Avatar
I agree with Jim.
Old Apr 14, 2005 | 03:28 PM
Yeah, what they said.
Old Apr 14, 2005 | 06:18 PM
SD70MAC's Avatar
Must be, I have an oem air filter and get a little oil in the intake.
Old Apr 14, 2005 | 07:02 PM
BennyTRD's Avatar
This is definetly the source of your build up.
Old Apr 15, 2005 | 08:58 AM
Babypig's Avatar
You can make a catch can very easily to remove some of the oil that gets by. You do have to watch the level in there after a while but it works quite well.
Old Apr 15, 2005 | 09:15 AM
BennyTRD's Avatar
Yeah Summit racing has quite a few different options there for you.
Old Apr 15, 2005 | 10:50 AM
3.4v6's Avatar
what jim said ... kind of like blow-by on turbos
Old Apr 15, 2005 | 04:18 PM
Babypig's Avatar
Just go buy a litre paint can and a little hose and a couple fitting and you in for about 10 bucks all in for a homemade one. Way cheaper.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
raiderhawks00
Jul 8, 2015 06:23 PM
