oil change question...
Old Feb 19, 2003 | 02:27 PM
Nolan's Avatar
so i changed my oil yesterday and being the bonehead that I am I only checked the oil level while my truck was cold (just after putting in the new oil). So I get home today after doing some running around and check the oil level just make sure it is ok. This time the oil is warm and it is about 1/8-3/16 of an inch over the Full line. Should I crawl under my truck and drain a little bit out or is it ok to leave it?
Old Feb 19, 2003 | 02:36 PM
EDGE's Avatar
If you put in the right amount I would leave it, on all my cars when and if I ever checked it after it was warm it was above
Old Feb 19, 2003 | 03:07 PM
Paul H.'s Avatar
You should be fine. That much over should be no problem.
Old Feb 19, 2003 | 03:10 PM
Salue's Avatar
Did you check the oil right after you turned the engine off? If so, that would read a little inaccurate also. You should wait a couple of minutes after you turn it off to let most of the oil drain back down into the drain pan.
Salue
Old Feb 20, 2003 | 06:54 AM
trd90toyota's Avatar
meh, 1/8 over fill won't kill it!
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
horunner1x
Jul 10, 2015 06:33 AM
