Oil Change
Originally posted by gene74
Do i really need a torque wrench for this job?
Thanks for all the replies. I went ahead and bought myself a torque wrench. You should see me looking at it silly on how to adjust it. But i finally figured it out. With the oil change, other than the oil spill in the driveway, i can say everything went smoothly. I have another question. Do you just hand tighten the oil filter or i need those oil wrenches also? I was under the truck for about 10 minutes looking for any leaks. You can say I'm nervous after doing it.
After doing this one, I wonder what other maintenance i can do now for the 4Runner?
Note:
You should always inspect for the old gasket from the previous filter, to insure that it came off with the old filter. "Double gasketing" the new filter will NOT seal properly, causing a serious oil leak and possibly severe engine damage.
Always use a new gasket on the drain plug.
Use of Non-chlorinated brake cleaner spray on oil residue left on components from taking off the oil filter, makes for a professional job.
Jay
Co-Founder/Administrator
Hi Gene, I use to do all of my own maintenance for years on all my own rigs, but can't do it anymore where I presently live now.
I always hand tightened the oil filter until it felt snug.
If you tighten it to much, you stand the chance of crushing the gasket and allowing oil to get past it and drip out.
After the filter has been on awhile, it's pretty hard to try and remove it by hand.
I always had to use an oil filter wrench to remove them.
I see Jay just beat me to the post here too
Also, put a little oil on the gasket before you put it on the block.
At least that is the way my dad taught me back in '75 when I had my first car.
Gee, I know i'm gonna messed something up sooner or later. Im done with my oil change. I did not know about that gasket. What can i do know? Can i still take the oil filter off then replace the gasket?
There wasn't a gasket on the OLD oil filter.
Now, I didn't add a new gasket on the new oil filter. Is this OK?
Jay
I almost doubled my total post just in this one thread. hehehehehehhe.
