Oem Wire Harness for Hella Fog Lights
Old Feb 7, 2005 | 11:51 AM
rev hank's Avatar
Question Oem Wire Harness for Hella Fog Lights
Have the oem Foglight wire harness(Hella Discontinued Part NO.96506, Toyota
Part #00550-89970WH) Closed system:harness, two plug ins for lights, relay, fuse holder, switch. It's basically a plug and play set up, but not certain which lights will fit the plugs. I'm thinking Hella 450.
any suggestions?
Thanks, Rev Hank
Old Feb 7, 2005 | 12:30 PM
SLC Punk's Avatar
Performance products sells both the individual lamps or you can get the complete kit from them.
Old Jun 29, 2005 | 06:52 PM
dv82u's Avatar
Fog Lights
Hey I saw that you had installed the performance fog lights. I installed mine, but it's not working. I checked the wiring, but I not so sure about the red/yellow wire at the bottom of the steering column. When I tried it, the fog light switch was on when I turned it on, but the fog lights don't work. Any advice? It's starting to frustrate me.
MO transplant
Apr 23, 2023 11:58 AM
Regency
20
Jan 3, 2020 07:43 PM
msane99
Jul 17, 2015 10:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
Johntom240
7
Jul 13, 2015 12:18 AM
