View Poll Results: What grade of octane do you use most frequently?
87
110
51.16%
89
41
19.07%
91
34
15.81%
93
30
13.95%
Voters: 215. You may not vote on this poll
octane rating?
Old Nov 19, 2003 | 07:45 AM
  #81
StingRay's Avatar
Reg Knows 7M's. If you are going turbo you will need to do the head gasket and lap the block and head on any 7M based engine.
Turbo's are not well known for serious out of the hole bottom end and may not be the best off road choice.
Actually Reg travels to Germany now and then for his Dinan BMW and TTE stuff.
I hadn't read your sig at the bottom and didn't get that it was a 7M that you had in your runner. YUP better gas will likely make a 7MGE make more power and get better milage.
Old Nov 19, 2003 | 08:12 AM
  #82
4runner4ever's Avatar
I used the 7M-GE because I didn't know what type of engine the supra had. I put a bid on an auction and got it without ever seeing it. I used it to make the swap, since I can allways get an 7M-GTE to bolt in.
Now that time has come, but the engine has busted a rod. I'm not sure what to do with it, repair the engine or use my 7M-GE short block as a donor and put all OEM 7M-GTE stuff, including head, on it.
Maybe I buy it just for the parts alone, like the wiring, ECU, Maf etc. Those things don't go around much overhere so....
Old Jan 28, 2004 | 07:33 PM
  #83
cctk2's Avatar
87, as it says use 87 less it starts to ping, which it doesnt. I do how ever TRY to buy Chevron when possible. Never was a believer in the stuff, but Ive done enough reading now, Techron IS a viable product, and why go through the hassle of adding it as a additive, when you can buy gas with it IN IT? :wtf:
Old Jan 29, 2004 | 08:45 AM
  #84
boogyman's Avatar
manual says 87, that's what i use
Old Jan 29, 2004 | 12:14 PM
  #85
DSP's Avatar
DSP
85 here....
Is colorado the only state that offers the 85 octane?
Old Jan 29, 2004 | 05:28 PM
  #86
Juggalo's Avatar
usullaly 93 for my 3.slow I need every single horse I can get with this pig
But with 93 being $1.84 per gallon I sometimes get 89
Old Jul 5, 2004 | 11:16 AM
  #87
jimmypage's Avatar
87 here
Old Jul 5, 2004 | 12:27 PM
  #88
4-RUNNIN' FREAK's Avatar
Sunoco 94 for me
Old Jul 6, 2004 | 11:13 PM
  #89
ByThaBay's Avatar
Originally Posted by 4-RUNNIN' FREAK
Sunoco 94 for me
costco 91
kawazx636
Oct 6, 2021 03:03 PM
4x4YOTA
Aug 23, 2016 09:08 AM
Firefightersink15
Nov 23, 2015 10:32 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Boomer8404
Sep 17, 2015 07:59 AM
