o2 Sensor Bad?
Old Aug 25, 2003 | 03:29 PM
4BangR's Avatar
o2 Sensor Bad?
I just replaced the cat and the whole exhaust system. Now there's a black buildup on the inside of the tailpipe. That means its running rich right? My guess is the O2 sensor is bad. How do you tell? It runs great, lots of power, no smoke or any problems. Thanks.
Old Aug 25, 2003 | 07:49 PM
Bumpin' Yota's Avatar
You probably have a bad O2 sensor like you think. That's what mine was and my gas milage suffered due to it.
Old Aug 26, 2003 | 03:57 PM
4BangR's Avatar
Thanks Bumpin'.
Does anyone know how to tell if the O2 Sensor is bad?
Old Aug 26, 2003 | 04:47 PM
MTL_4runner's Avatar
Originally posted by 4BangR
Thanks Bumpin'.
It kinda sucks to test it cause you gotta probe it with a multimeter when hot (careful!).
Check the values you get with a good service manual to see if the sensor is still good.
If no, then replace......or you can just replace and see if it helps.
Old Aug 26, 2003 | 04:49 PM
AgRunner06's Avatar
Post
My guess is that your O2 sensor is old anyways. So just go ahead and replace it.
Old Aug 26, 2003 | 06:08 PM
4BangR's Avatar
Thanks guys. I think I will probably just replace it sometime.
mtnfreak's Avatar
If it's never been done, just replace it. If you're the curious type, trace the wire from the sensor, through the floor and under the seat. Separate the plug there and test the sensor side - the two terminals away from the plastic snaplug that holds the wire to the body should have a resistance of 5.1 - 6.3 ohms at 20degC (68degF). There's another test, but it's way too detailed to post here and probably requires two people.
sandyota
Feb 4, 2021 11:16 AM
raptor510
Feb 17, 2017 07:11 AM
nonstop
Jul 24, 2015 06:29 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
