O/d
Old Dec 10, 2003 | 08:24 PM
O/d
I have a 93 V6 with A/T and when i get on the highway sometimes my overdrive doesn't kick in for a while does anyone have an idea as to why it doesn't kick in. Its done it a few times now and im starting to think that there may be a problem
thanks
Old Dec 10, 2003 | 08:58 PM
Babypig's Avatar
Could be a couple things. First i would look at the kick down cable, then test the TPS and make sure that it is with specs. Then i would look at the cooling system as the overdrive is temp controled. It won't shift into overdrive if the temp isn't right, and if you are driving on the highway it may be too cool. Check the Temp sensor. Pull the codes and see if there is any trans codes that pop up indicating a solenoid.
Old Dec 11, 2003 | 02:04 PM
DrumheadAR's Avatar
try doing a search...
There was a thread about this a month ago or so. I can't remember if they fixed it, but there were a lot of replies.
Old Dec 12, 2003 | 07:30 PM
towman3500hd's Avatar
o/d problem
Click "search", then type in "o/d problem" & you will see the post from a few weeks ago. I posted the Toyota part number of the Temp switch.
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
vanion2
Jul 29, 2015 06:17 PM
Kiff
Oct 2, 2007 03:40 PM
vegascoug
Feb 12, 2007 01:50 PM
