Noob looking for help wiring my hella700s
Old Aug 14, 2010 | 09:03 AM
bak3rme's Avatar
Need some help wiring my hella700s. In the box i had 2 separate wires. one was a 1 foot long blue wire which i know is the ground wire for my switch..the other was a long green wire. which runs from switch to i do not know what. its weird because for the green wire it only has a female end of the "fuse" connector piece. I donno where the male end of it is.
I know the yellow wire runs from relay to switch. Black wires run to relay. Red wire runs from relay to battery.
whats the easiest way i can wire these lights?
i do not understand the "tapping" method where i tap into other fuses.
My green cable looks like this on both ends of the same wire:
i need the other end of the green wire which looks like this, is the other end of it located on the vehical?:
that wire in the middle is the ground for the switch right? if so ..then the other blue wires coming out of the lights are ground also right? am i suppose to buy a spade clamp and clamp it down?
am i suppose to clamp something onto here:
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
jbandt
Aug 3, 2015 03:23 PM
cgilley
Jul 25, 2015 10:55 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
