Noob looking for help wiring my hella700s
Need some help wiring my hella700s. In the box i had 2 separate wires. one was a 1 foot long blue wire which i know is the ground wire for my switch..the other was a long green wire. which runs from switch to i do not know what. its weird because for the green wire it only has a female end of the "fuse" connector piece. I donno where the male end of it is.
I know the yellow wire runs from relay to switch. Black wires run to relay. Red wire runs from relay to battery. whats the easiest way i can wire these lights? i do not understand the "tapping" method where i tap into other fuses. My green cable looks like this on both ends of the same wire:http://i43.photobucket.com/albums/e3...1/IMG00063.jpg i need the other end of the green wire which looks like this, is the other end of it located on the vehical?: http://i43.photobucket.com/albums/e3...1/IMG00067.jpg that wire in the middle is the ground for the switch right? if so ..then the other blue wires coming out of the lights are ground also right? am i suppose to buy a spade clamp and clamp it down? http://i43.photobucket.com/albums/e3...1/IMG00068.jpg am i suppose to clamp something onto here: http://i43.photobucket.com/albums/e3...1/IMG00065.jpg |
