noise after changing spark plugs
Old Mar 21, 2007 | 05:27 PM
yotarunner96's Avatar
hi,
i recently took my 96 v6 4runner and got the spark plugs changed at the dealer. ever since i got it back the motor just does not seem to have the same idle hum or sounds. from the outside it sounds normal but sitting in the drivers seat there is a change you can hear which almost resembles a very quiet diesel motor. i took it back asking why, wondering if plugs were arching or anything else and they said it was normal. does anyone have any feed back on what i could check next. i was wondering if it would need a valve adjustment but i have read that those are not common at all with these motors with 130k on it. but it has seemed to be sluggish lately too. thanks
Old Mar 22, 2007 | 04:09 AM
mkgarrison5's Avatar
pull one out and make sure its gapped correctly for starts. i know its a dealer that put them in but you never know.. plus unhook the gound wire on your battery for a few minutes to reset the computer... also look into seafoam here. do a search for it.. it cleans the intakes and etc very well.
Old Mar 22, 2007 | 07:06 AM
profuse007's Avatar
does it idle the same as b4?
Old Mar 22, 2007 | 08:26 AM
no it idles different than before i changed them. i noticed that, told the dealer, and they said it was normal. for some reason i dont believe them though
Old Mar 22, 2007 | 08:44 AM
91TPU's Avatar
when you say different is the idle higher or lower? and what kinda plugs were removed?
Old Mar 22, 2007 | 01:42 PM
idles at the same rpm, and they were oem toyota plugs. i dont know what was in it and what went back in, i just know that it was done by the dealer
Old Mar 22, 2007 | 01:46 PM
BlackSR5's Avatar
maybe something fell in the plug hole and they didnt realize it?
Old Mar 22, 2007 | 02:51 PM
Bennito's Avatar
pull the easiest plug. I think it'll be drivers side front. Verify brand / model. (replace) Post your findings.
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
razorman8669
Jul 12, 2015 12:13 PM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
