noise in 4wd
Old Sep 27, 2004 | 05:08 PM
94yotaSup's Avatar
noise in 4wd
I just recently bought a 1994 reg cab 22re yota. When I put it into 4H i get a loud noise/vibration above 25mph. I'm not sure if it's there in 4L. The manual says to check the torque of the driveline bolts....where are these?
I just changed the transfer case oil and that didn't help. Should I change the front diff fluid also? How do I check the u-joints?
Thanks for the help ....I'm new to the 4x4 world!
Old Sep 28, 2004 | 07:43 AM
eric-the-red's Avatar
Driveline bolts are the bolts connecting the driveshafts to the transfer case and diff flanges, 4 bolts at each end of both shafts. I don't have the exact torque specs but I would make sure they are as tight as you can get them with a wrench.
As for the u-joints if you grab the driveshaft with one hand on each side of the joint and twist in opposite directions there should be no play in the joint.
And I would go ahead and change tho oil in both diffs, unless you know for sure it's been done recently.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
genuinegemini
Aug 3, 2015 04:56 PM
Athansinis
Jul 27, 2015 08:38 AM
ripp96
Jul 25, 2015 02:32 PM
