no power to the rear
Old Aug 28, 2003 | 08:05 PM
FynACK's Avatar
Unhappy no power to the rear
I have 96 4runner that appears to have no electrical power to the rear. The rear window doesnt roll down either from the dash or by key and the rear wiper does not function as well. If any know what could be the problem I would greatly appreciate it. Ive checked fuses but I can not determine which one controls the rear end.
Thanks
Old Aug 28, 2003 | 08:08 PM
Yoter's Avatar
Guest
Checked the fuses with a test light or by eye? If youve got a test light use it and check them all. If not it should say on the cover whats what or in the manual. Sounds like a fuse though. Test lights can be found for $5 at a parts place sometimes. GL
Old Aug 28, 2003 | 08:09 PM
taco04's Avatar
Make sure that your window lock button isnt down on the driver side. I freaked out once when mine wouldnt roll down. As it turned out, i had accidentally pressed that button.
Old Aug 28, 2003 | 08:11 PM
FynACK's Avatar
Thanks for ur replys .... i will give the test light a try but how would i check the fuses that have solid covers on them?
Old Aug 28, 2003 | 08:12 PM
Yoter's Avatar
Guest
LOL ive done that very same thing and was like HUH. Eventually I figured it out and felt stupid. He said his wiper was INOP also. Unless there is a chance of him pushing that button accidently and the wiper motor going out or fuse blowing. Hard to say. Check the switch, check the fuses, then you will have an answer.
Old Aug 28, 2003 | 08:28 PM
Victor's Avatar
wiper motor won't work if the rear windos is even slightly open.
Old Aug 28, 2003 | 08:41 PM
Yoter's Avatar
Guest
Uh I knew that! Ok I forgot about that. I wonder if he is laughing as I did when I did that. So like SportEdition said about that console switch being pushed is prolly the correct answer. Fyn look into what Sport said. Then go to all of the troyble I gave you if no luck. Sorry man
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
icentropy
Jul 14, 2015 10:23 AM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
